Android Groundwire Push with TLS
trumee
I am using TLS/SRTP with groundwire app on android with FreePBX. The push mechanism is working as expected.
I want to use FusionPBX (FPBX) instead, and stood up a server. Unfortunately, the push mechanism on FPBX worked fine when using UDP transport, but it doesnt work properly when using TLS (SIPS). The FPBX straight away goes to voicemail, and the groundwire app doesnt re-register from their push server to the FusionPBX server.
Has anybody been successful in using Fusionpbx+TLS/SRTP+Groundwire with Push? I am wondering if there is any trick i may be missing.
xisonc
Not sure about SRTP, never used it, but setting the Groundwire to use TLS (sips) works for me.
I believe it requires a valid SSL/TLS cert (not self signed) in Freeswitch.
