Busy Signal
Incubugs
175
Is there any way at all to get the systemn to say user busy on screen instead of normal clearing when an external number is dialled and is busy ? Its casuing users to complain they are being cut off when in fact the calls simply busy
Thnaks
I
It's a while ago, but I think we solved this by setting
continue_on_fail=false
in the outbound route prior to the bridge statement.
hhijawi
13
I am trying to use continue_on_fail=false in a paging dialplan to drop the call if one of the receivers is busy. can this be done?
I am trying to fix a case when two extensions press call at the same time, in that case I want to drop the call for both.
flowing are my dialplan and sngrep snapshot.
