Call rings twice on the phone
MTR
181
I did an upgrade from ver 4.4 to the master latest version,
user are reporting that now instead of the call going to voice mail after the timeout period (30 seconds) it will show on the phone a missed call but right away start ringing again for another 30 seconds before it goes to VM
anyone?
krishanodedra
anyone?
Yes I am running into the same issue as well. Haven't figured out a fix yet.
566
Thanks for making us aware. If you actually want people to help you, you may want to start posting some logs. ;)
krishanodedra
Just checking in. We are still having this issue.
Version4.5.7Git InformationBranch: master
Status: Your branch is up-to-date with 'origin/master'. +0 days ago
Project Path/var/www/fusionpbxSwitch Version1.8.4 (64bit)Operating System Information Operating SystemDebianVersion9.9
MTR
181
Under dailplan check if you have 2 dailplan with the name vociemail
krishanodedra
Yes I do, both have a number [ext] but one value is the external dns name of our server and the other one say's ${domain_name}
Both are enabled.
krishanodedra
Both are enabled.
OK! setting them to false didn't work but once I deleted the extra entries it’s working again.
Thanks for your help!
MTR
181
The disable didn't work cause you didn't refresh the cache
However it's safe and the right thing do delte it
