SOLVED Can't block IP bruteforcing my PBX
fusionpbxuser888
Hello!
Someone is trying to find a correct extension number to (attempt to) register to my PBX.
Like this:
1    INVITE     3500@<mypbx-ext-Ip-num>        90048323395006@<mypbx-Ip-gateway>     37.49.229.183:19101    <mypbx-int-ip-num>:5060        CALL SETUP
I tried to have Fail2Ban block it, with a manually-added IP address, but no luck. So I put a rule in iptables myself (this is Debian 10):
# iptables -L
Chain INPUT (policy DROP)
target     prot opt source               destination
DROP       all  --  37.49.229.183        anywhere
S/He just keeps coming at me. Why doesn't IP tables stop the request from getting to Freeswitch?
Thanks... I acutally have more serious problems I may post about shortly, but this was annoying me by quickly filling up all the space on the screen in sngrep.
197
sngrep will show traffic even if it isn't making it to freeswitch. check for freeswitch responses to test if your rules are working.
fusionpbxuser888
Hmm. That blows my mind a bit, but I guess like a packet sniffer it picks up traffic right off the interface? As you see below (similar but different attacker) there was no response. THANK YOU!
                                                             INVITE sip:01011972592277524@mypbxIP SIP/2.0
           163.172.230.4:60389             172.16.0.7:5060  │Via: SIP/2.0/UDP 0.0.0.0:60389;branch=z9hG4bK640761392
          ──────────┬─────────          ──────────┬─────────│Max-Forwards: 70
  17:55:25.832800   │        INVITE (SDP)         │         │From: <sip:010111586921145:5060@mypbxIP>;tag=1550460620
                    │ ──────────────────────────> │         │To: <sip:01011972592277524@mypbxIP>
                    │                             │         │Call-ID: 1445230276-501814850-1473650658
                    │                             │         │CSeq: 1 INVITE
                    │                             │         │Contact: <sip:010111586921145:5060@212.129.10.158:60389>
                    │                             │         │User-Agent: pplsip
                    │                             │         │Content-Type: application/sdp
                    │                             │         │Content-Length: 209
                    │                             │         │v=0
                    │                             │         │o=010111586921145:5060 16264 18299 IN IP4 0.0.0.0
                    │                             │         │s=pplsip
                    │                             │         │c=IN IP4 0.0.0.0
                    │                             │         │t=0 0
                    │                             │         │m=audio 25282 RTP/AVP 100 6 0 8 3 18 5 101
                    │                             │         │a=rtpmap:0 pcmu/8000
                    │                             │         │a=rtpmap:101 telephone-event/8000
                    │                             │         │a=fmtp:101 0-11
