Change recording Archive to not use data
coldfireza
Hi
Currently Fusion creates archive/2021/Aug/Day etc etc
I would like the archive to just be one folder of recordings, I need to process calls for upload to a longterm recording storage provider and would be easier to manage with one location
Thanks in advance
Depending on configuration, recording file locations are normally controlled by the record_path channel variable. Have a look at the user_record dialplan in your dialplan manager. You will probably find the record path being set similar to this:
record_path=${recordings_dir}/${domain_name}/archive/${strftime(%Y)}/${strftime(%b)}/${strftime(%d)}
Edit it to meet your needs.
