SOLVED Changing Call Recording Location
Kenny Riley
243
Hi there
I added a secondary data drive for the purpose of storing call recordings, however, I can't find any information on how to change the call recording location/path. Could anyone help me out?
Thank you!
Kenny Riley
243
I had this answered in the IRC chat. Just needed to change the directory of the recordings from the default settings > switch > recordings directory
May 16, 2017
103
Hi - I have tried to change the location here and rebooted the server but its not made a difference. - Any advice would be great.
Kind Regards
Andy
Len
95
Andrew, Have you solved this issue?I am having the same problem changes of recording file location is not getting saved. the variable still holds the old/default path.
FSM
i am having the same problem.
pogingbagsik
14
Managed to achieve this by moving or delete the default recording path and create a symlink to the mounted drive.
Hoping it helps :)
