SOLVED Custom MOH for a specific domain
Kenny Riley
243
Is it not possible to have a custom music on hold for a domain? From the domain I want to assign a specific MOH to, I went to Apps > Music on hold, added a new category, uploaded my files, and assigned that new category to the specific domain, but the default music on hold continues to play.
Anyone know how to get this working?
Kenny Riley
243
Ahhh I see the setting you're talking about.. I didn't think to check at the extension level. Thank you!!
Kenny Riley
243
You need to set it per extension ..
Well.. This doesn't appear to be working. I set the MOH on an extension to the MOH category I created and it's still playing the default hold music from that extension where I configured the MOH category?
Kenny Riley
243
Still no luck.. I've set the MOH at the extension level as shown below and then flushed the memcache..
Here's my custom MOH category:
566
I don't think that path should have 48000 in it, it shouldn't have any number in there. Freeswitch should determine that for itself.
Kenny Riley
243
Ahh you're right! I deleted and recreated the category under 8khz and that did it. Thanks Daz!
Feb 8, 2018
55
I have another small problem. I have deleted all files in default categories. Now I would upload something in default/8k, 16k, 32k and 48k but every time the upload seems to charge something but at the end of upload the category remain empty
