SOLVED Destination Number of inbound call
Stelios
I Test Fusion PBX and it looks nice ...
I use a VoIPTrunk and I need to register. The Gateway is working fine for inbound/outbound calls.
The Issue is that I have 3 DID numbers for inbound Calls. At the inbound call the destination DID Number is missing and as Destination number is the username that I use to register at the Gateway!
Based on the about I can not make inbound routes based on the DID number that some use to call me!
There is some one who knows how to fix that?
566
Sorry, I cannot quite understand, are you saying the carrier is not sending the inbound number?
Stelios
The incoming call include as Destination number the username (that we use at our gateway), So we can not have different inbound rules based on the DID number.
Lets say that we have two DIDs, the one is 5555555555 and the second is 7777777777.
When some one use the DID 5555555555 we need to ring the extension 100
When some one use the DID 7777777777 we need to ring the extension 200
The issue is that when the call arrives to FusionPBX does not have as Destination number the DID but as Destination has the username. SO we can not make rules based on the the Dialed DID.
Note we have test the same DIDs with 3cx IPPBX and there is not any issue
566
@Stelios Can you post a copy of the inbound sip INVITE please.
Or just paste a full call log of a call.
In fs_cli do a:
sofia global siptrace on
Then make the call
Stelios
See attachment
Also note this
2017-09-27 14:21:31.868979 [INFO] mod_dialplan_xml.c:637 Processing 6944699858 <6947699858>->XDF90034 in context public
This => XFF40034 should be 2132241050
566
The actual piece I wanted, ie the INVITE, is about the only part you missed from that :)
566
Anyway, if its what I think, do this....
Create a destination as normal, see attached screenshot.
Then go into the inbound route for that the destination created, you will see it like the following:
Then change the condition from destination_number to ${sip_to_user} as shown below.
This should fix things for you.
