Dialplan entry global-variables sanity check
Does anyone have a handle on what I think is a relatively new dialplan entry called global-variables. I'm pretty sure it has appeared in installations later that 9th January. The reason I ask it I'm seeing its action appearing repeatedly in the fs_cli. This test box only has five domains on it but I see this for a single inbound call:
EXECUTE [depth=0] sofia/external/01123456789@myprovider.co.uk set(RFC2822_DATE=Fri, 21 Feb 2020 13:59:52 +0000)
2020-02-21 13:59:52.406075 [DEBUG] mod_dptools.c:1672 SET sofia/external/01123456789@myprovider.co.uk [RFC2822_DATE]=[Fri, 21 Feb 2020 13:59:52 +0000]
global-variables is created for each domain, so its not technically global, but its context is set to ${domain_name}, something doesn't look right about this...
197
I don't see this dial plan on my production server, but I do see it on a recent test server.
This seems like a bug where it should either be defined as either Global, or the context equals the actual domain name. I would assume it should be changed to "domain"="Global" and any duplicate dial plans should be removed.
The domain template file would also need to be modified to correct the bug. Sound like you should submit a bug report and/or a PR with corrections.
Reactions: Adrian Fretwell
markjcrane
450
162
Posting bugs here makes them harder to find and not as likely to get fixed however I found this one and fixed the issue reported by original post.
p.s. "domain"="Global" this currently doesn't work but I have considered making it possible current global domains need a context of ${domain_name}
Thankyou Mark. The post wasn't meant to be a bug report, just as it says, a sanity check for me. I have raised several other tickets as I'm sure you are aware. I know how busy you are currently an did not want to add to that workload with what could have been a "Nothing" report.
Cheers,
Adrian.
markjcrane
450
162
It turned out to be good thing because then it was brought to my attention and got fixed. Sorry I missed the 'sanity check' in the title... And I have noticed your other bug reports which will be worked on as time permits.
Thanks for bringing it up so it could be fixed.
