enable the record for outgoing and incoming calls
djebali
42
Hello everybody
I'm wondering to find the way to activate recording incoming and outgoing calls on fusionpbx
do someone can tell me how to activate by default?
I thank you
sami
As far as I am aware, there is no easy of doing this by default, you activate it in the extensions settings, there is a record option, you can choose 'all' in there.
I think there are certain types of call it does not record that need to be added separately. Maybe conference. Anyone else know??
djebali
42
Hello Luis and digitalDaz
i than you for your support
question , after adding this in the dialplan will it be visible in the cdr ?
i thnak you
sami
It should be as long as the file is in the right place, which I think it is from Luis' setting
djebali
42
Good Morning DigitalDaz
I thank you i'll try to do it and keep you informed
I really thank you
sami
Mike LeRoy
I just set a line to record. After how many seconds/minutes will the recording be kept? Is there a minimum length setting?
Mike
Mike LeRoy
I set it up and saw a file created, when the phone was hung up it was deleted - 30 seconds maybe.
No, there is no logic there to do that, you using the stable version?
Mike LeRoy
The problem was an "action" on the outbound was "set" to "bypass_media=true" - this was set to maybe fix another problem. Setting to false leaves the recordings.
MTR
181
Easy, put a dialplan to set user_record variable to all
Other way is adding the instruction
record_session $${recordings_dir}/${domain_name}/archive/${strftime(%Y)}/${strftime(%b)}/${strftime(%d)}/${uuid}.${record_ext}
All with dialplan.
this worked well for me
now i am going to work on a script to email the file and then delete from server will post my output
Len
95
Hello, have you created the script? Do you mind to share it? Cheers!
ppenkov
All with dialplan.
Hello, excuse me for re-opening this old post, but I'm looking to achieve exactly this thing.
I'm new to FusionPBX, so could you explain me, please, where and how to configure this ?
Thank you!
You do not need to do this, in extension settings just set record to all
ppenkov
Thank you for the advice, but even if I set that option, I can't find the recordings.
I did one outbound call and one internal....look at Apps -> Call Recording and there is nothing...Nothing in Apps -> Recordings too....
You should be able to just look in CDRs. It should have a play and download button.
If not, have you done an upgrade between versions recently??
ppenkov
My CDRs is look like this:
Is this the right place to look ?
I'm using a fresh install of the 4.4
