Fail2ban blocking outbound trunk
Matthew Main
92
Hey guys anyone ever had an issue with fail2ban and iptables auto blocking the ips for a gateway?
i use Simwood and all gateways point to out.simwood.com
It seems to be getting flagged so i cant ping the dns entries or there direct ips until fail2ban is off and iptables rules have been cleared
any ideas?
cheers
Matt
The answer will be in your log files, see when they got banned in the fail2ban log, then match that in your freeswitch log.
Reactions: Matthew Main
ZPM
64
I have made a mistake before with the jail.conf file that caused fail2ban to block my SIP trunk provider IP. The ignoreip= field I accidentally added a customer router IP without the CIDR. XXX.XXX.XXX.XXX BAD XXX.XXX.XXX.XXX/32 GOOD
Incubugs
175
This happens every single time i install a new pbx, you simply add it to teh fail2ban ignore as said above and it stops the issue, not sure why it bans it just know it must be added, which is probably best practice anyway :)
I have had this happen when I have registered a gateway with a SIP provider but forgot to create a destination (inbound route). Freeswitch then puts something like "DID not found" and the SIP providers IP address in the log which fail2ban then picks up on.
