Freeswitch and PBX security
yukon
138
14
Was wondering what everyone's security ideas are. How do you keep your system secure, how do you protect your provisioning, etc.
For me:
  • All customers required to have static IP
  • IP tables configured to only allow those IP's on 5060, etc
  • Only https enabled, any IP can hit 443
  • Use CIDR in fusionpbx provisioning
  • Use http auth password for fusionpbx provisioning
  • fail2ban setup with fusionpbx installed scripts and a couple custom ones.
Any other ideas and how do you handle security?
NateDoc
All accounts use named domains - that limits attackers dramatically since without knowing the domain name they can't ever successfully invite. Goes without saying not to use the domain in rDNS for this to be effective.
566
I have customers with static and dynamic IP
Provisioning I still do in the clear.
I also only use domain names and block anything that so much as sniffs at the IP
The current rule.v4 I think I have just posted on here somehwere
roger_roger
198
19
I used to block all address except my customer's but then we started offering a mobile client and that made it mandatory that we do not block any addresses.
I have an ACL on my router that blocks most RIPE addresses and some other large blocks that I have identified as being potentially bad. I also have fail2ban set pretty aggressively as well.
