SOLVED Freeswitch process not running on FusionPBX fresh install
meshtask
17
I have tried to install FusionPBX latest version on Debian 11 64 bit.It installs and web interface works fine.
But for some reason, freeswitch process is not starting at all and the command "fs_cli" says "command not found".
Is this some new bug in install script?
lizz850517
I got the same issue too, got the same error since yesterday.
Even on Ubuntu, install failed.
I've tried several times on GCP VM(Debian11 and Ubuntu 20.04)
Adrian Last
Seems as spandsp may be causing the compiler to stop
checking for spandsp >= 3.0... configure: error: no usable spandsp; please install spandsp3 devel package or equivalent
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target 'install'. Stop.
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
lsb-release is already the newest version (11.1.0).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
switch/source-sounds.sh: 89: ../environment.sh: verbose: not found
make: *** No rule to make target 'sounds-install'. Stop.
make: *** No rule to make target 'hd-sounds-install'. Stop.
make: *** No rule to make target 'cd-sounds-install'. Stop.
mv: cannot stat '/usr/share/freeswitch/sounds/music/*000': No such file or directory
chown: cannot access '/var/lib/freeswitch': No such file or directory
chown: cannot access '/var/log/freeswitch': No such file or directory
E: Unable to locate package freeswitch-systemd
Job for freeswitch.service failed because the control process exited with error code.
See "systemctl status freeswitch.service" and "journalctl -xe" for details.
