FusionPBX DB listen from outside network?
Tuly
42
I would like to have a billing system pull CDR records from the DB "v_xml_cdr" what changes do I need to make to the fusion PBX config that it should listen to an Outside IP? because so far whatever I try is not working, it looks like the server DB is not listening only to the local server
Tuly
42
thank you, All the documentation I'm looking at are a are a bit outdated, would you mind posting the path? and how to enable only outside IP
Thank you again!
566
Just find it, it will differ depending on your build:
find / -name pg_hba.conf
In the postgresql.conf in the same directory there will be a 'Listen' bit probably commented out you just need to put * in there but it is explained in the comments.
markjcrane
453
162
Use a search engine with these keywords "postgresql external connections" From that you will find multiple guides on this topic.
Reactions: JamesBorne
