FusionPBX Grafana Visualisation
whut
170
15
Shout out if you need any assistance getting up and running,
Thank you!
I would suggest an edit to your readme. "You can find your password in /etc/fusionpbx/config.php" config.php and config.lua are the old method. Perhaps for a year now config.conf has replaced those 2 files. Config.conf is easier to parse.
Edson
59
Good solution! I am not familiar with Go language but i can see that it extract all the info directlly from postgresql db itself. I am devloping a Dialer and Call Center Dashboard for Grafana. It handles all the real time info in a very different approach. It reads events of freeswitch using LUA scripts and send to a Redis Db. Then Grafana can handle it properlly. Regards!
whut
170
15
That sounds great! I would love to see this as you get close to unveiling.
