FusionPBX voicemail messages being cut off
mudasar321
84
-- Part of FusionPBX
-- Copyright (C) 2013 Mark J Crane <markjcrane@fusionpbx.com>
-- All rights reserved.
-- Redistribution and use in source and binary forms, with or without
-- modification, are permitted provided that the following conditions are met:
-- 1. Redistributions of source code must retain the above copyright notice,
-- this list of conditions and the following disclaimer.
-- 2. Redistributions in binary form must reproduce the above copyright
-- notice, this list of conditions and the following disclaimer in the
-- documentation and/or other materials provided with the distribution.
-- THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES,
-- INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY
-- AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-- AUTHOR BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
-- OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
-- SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
-- INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
-- CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
-- ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
-- POSSIBILITY OF SUCH DAMAGE.
--load libraries
local Database = require "resources.functions.database"
local Settings = require "resources.functions.lazy_settings"
local JSON = require "resources.functions.lunajson"
--define uuid function
local random = math.random;
local function gen_uuid()
local template ='xxxxxxxx-xxxx-4xxx-yxxx-xxxxxxxxxxxx';
return string.gsub(template, '[xy]', function (c)
local v = (c == 'x') and random(0, 0xf) or random(8, 0xb);
return string.format('%x', v);
end)
end
--define escape function (prevents lua injection attacks)
local function esc(x)
return (x:gsub('%%', '%%%%')
:gsub('^%^', '%%^')
:gsub('%$$', '%%$')
:gsub('%(', '%%(')
:gsub('%)', '%%)')
:gsub('%.', '%%.')
:gsub('%[', '%%[')
:gsub('%]', '%%]')
:gsub('%*', '%%*')
:gsub('%+', '%%+')
:gsub('%-', '%%-')
:gsub('%?', '%%?'))
end
local function transcribe(file_path,settings,start_epoch)
--transcription variables
if (os.time() - start_epoch > 2) then
local transcribe_provider = settings:get('voicemail', 'transcribe_provider', 'text') or '';
transcribe_language = settings:get('voicemail', 'transcribe_language', 'text') or 'en-US';
if (debug["info"]) then
freeswitch.consoleLog("notice", "[voicemail] transcribe_provider: " .. transcribe_provider .. "\n");
freeswitch.consoleLog("notice", "[voicemail] transcribe_language: " .. transcribe_language .. "\n");
end
if (transcribe_provider == "microsoft") then
local api_key1 = settings:get('voicemail', 'microsoft_key1', 'text') or '';
local api_key2 = settings:get('voicemail', 'microsoft_key2', 'text') or '';
if (api_key1 ~= '' and api_key2 ~= '') then
access_token_cmd = "curl -X POST \"https://api.cognitive.microsoft.com/sts/v1.0/issueToken\" -H \"Content-type: application/x-www-form-urlencoded\" -H \"Content-Length: 0\" -H \"Ocp-Apim-Subscription-Key: "..api_key1.."\""
local handle = io.popen(access_token_cmd);
local access_token_result = handle:read("*a");
handle:close();
freeswitch.consoleLog("notice", "[voicemail] CMD: " .. access_token_cmd .. "\n");
freeswitch.consoleLog("notice", "[voicemail] RESULT: " .. access_token_result .. "\n");
end
--Access token request can fail
if (access_token_result == '') then
freeswitch.consoleLog("notice", "[voicemail] ACCESS TOKEN: (null) \n");
return ''
end
transcribe_cmd = "curl -X POST \"https://speech.platform.bing.com/re...=D4D52672-91D7-4C74-8AD8-42B1D98141A5&locale=" .. transcribe_language .. "&device.os=Freeswitch&version=3.0&format=json&instanceid=" .. gen_uuid() .. "&requestid=" .. gen_uuid() .. "\" -H 'Authorization: Bearer " .. access_token_result .. "' -H 'Content-type: audio/wav; codec=\"audio/pcm\"; samplerate=8000; trustsourcerate=false' --data-binary @"..file_path
local handle = io.popen(transcribe_cmd);
local transcribe_result = handle:read("*a");
handle:close();
freeswitch.consoleLog("notice", "[voicemail] CMD: " .. transcribe_cmd .. "\n");
freeswitch.consoleLog("notice", "[voicemail] RESULT: " .. transcribe_result .. "\n");
end
--Trancribe request can fail
if (transcribe_result == '') then
freeswitch.consoleLog("notice", "[voicemail] TRANSCRIPTION: (null) \n");
return ''
else
status, transcribe_json = pcall(JSON.decode, transcribe_result);
if not status then
freeswitch.consoleLog("notice", "[voicemail] error decoding bing json\n");
end
return '';
end
end
if (transcribe_json["results"][1]["name"] == nil) then
else
freeswitch.consoleLog("notice", "[voicemail] TRANSCRIPTION: " .. transcribe_json["results"][1]["name"] .. "\n");
end
if (transcribe_json["results"][1]["confidence"] == nil) then
freeswitch.consoleLog("notice", "[voicemail] CONFIDENCE: (null) \n");
else
freeswitch.consoleLog("notice", "[voicemail] CONFIDENCE: " .. transcribe_json["results"][1]["confidence"] .. "\n");
end
end
transcription = transcribe_json["results"][1]["name"];
transcription = transcription:gsub("<profanity>.*<%/profanity>","...");
confidence = transcribe_json["results"][1]["confidence"];
return transcription;
end
end
if (transcribe_provider == "azure") then
local api_key1 = settings:get('voicemail', 'azure_key1', 'text') or '';
local api_server_region = settings:get('voicemail', 'azure_server_region', 'text') or '';
if (api_server_region ~= '') then
api_server_region = api_server_region .. ".";
else
freeswitch.consoleLog("notice", "[voicemail] azure_server_region default setting must be set\n");
end
return '';
end
if (api_key1 ~= '') then
-- search in memcache first, azure documentation claims that the access token is valid for 10 minutes
local cache = require "resources.functions.cache";
local key = "app:voicemail:azure:access_token";
local access_token_result = cache.get(key)
if access_token_result then
freeswitch.consoleLog("notice", "[voicemail] Azure access_token recovered from memcached\n");
end
else
access_token_cmd = "curl -X POST \"https://"..api_server_region.."api.cognitive.microsoft.com/sts/v1.0/issueToken\" -H \"Content-type: application/x-www-form-urlencoded\" -H \"Content-Length: 0\" -H \"Ocp-Apim-Subscription-Key: "..api_key1.."\"";
handle:close();
freeswitch.consoleLog("notice", "[voicemail] ACCESS TOKEN: " .. access_token_result .. "\n");
end
end
return ''
end
--Azure returns JSON when it has to report an error
if (string.sub(access_token_result, 1, 1) == '{') then
freeswitch.consoleLog("notice", "[voicemail] ERROR STRING: ".. access_token_result .. "\n");
end
return ''
end
cache.set(key, access_token_result, 120);
freeswitch.consoleLog("notice", "[voicemail] Azure access_token saved into memcached: " .. access_token_result .. "\n");
end
end
transcribe_cmd = "curl -X POST \"https://"..api_server_region.."stt.speech.microsoft.com/speech/recognition/conversation/cognitiveservices/v1?language=".. transcribe_language .."&format=detailed\" -H 'Authorization: Bearer " .. access_token_result .. "' -H 'Content-type: audio/wav; codec=\"audio/pcm\"; samplerate=8000; trustsourcerate=false' --data-binary @"..file_path
handle:close();
end
return ''
end
local transcribe_json = JSON.decode(transcribe_result);
if (transcribe_json["NBest"][1]["Display"] == nil) then
else
freeswitch.consoleLog("notice", "[voicemail] TRANSCRIPTION: " .. transcribe_json["NBest"][1]["Display"] .. "\n");
end
if (transcribe_json["NBest"][1]["Confidence"] == nil) then
else
freeswitch.consoleLog("notice", "[voicemail] CONFIDENCE: " .. transcribe_json["NBest"][1]["Confidence"] .. "\n");
end
end
transcription = transcribe_json["NBest"][1]["Display"];
confidence = transcribe_json["NBest"][1]["Confidence"];
end
end
if (transcribe_provider == "custom") then
local transcription_server = settings:get('voicemail', 'transcription_server', 'text') or '';
local api_key = settings:get('voicemail', 'api_key', 'text') or '';
local json_enabled = settings:get('voicemail', 'json_enabled', 'boolean') or "false";
if (transcription_server ~= '') then
transcribe_cmd = "curl -X POST " .. transcription_server .. " -H 'Authorization: Bearer " .. api_key .. "' -F file=@"..file_path
local transcribe_result = esc(handle:read("*a"));
handle:close();
end
return ''
end
if (json_enabled == "true") then
if (transcribe_json["message"] == nil) then
freeswitch.consoleLog("notice", "[voicemail] TRANSCRIPTION: " .. transcribe_result .. "\n");
transcribe_result = '';
end
if (transcribe_json["error"] ~= nil) then
end
transcribe_result = transcribe_json["message"];
end
return transcribe_result;
end
end
else
freeswitch.consoleLog("notice", "[voicemail] message too short for transcription.\n");
end
end
return '';
end
--save the recording
function record_message()
local db = dbh or Database.new('system')
local settings = Settings.new(db, domain_name, domain_uuid)
local max_len_seconds = settings:get('voicemail', 'message_max_length', 'numeric') or 300;
transcribe_enabled = settings:get('voicemail', 'transcribe_enabled', 'boolean') or "false";
freeswitch.consoleLog("notice", "[voicemail] transcribe_enabled: " .. transcribe_enabled .. "\n");
freeswitch.consoleLog("notice", "[voicemail] voicemail_transcription_enabled: " .. voicemail_transcription_enabled .. "\n");
end
--record your message at the tone press any key or stop talking to end the recording
if (skip_instructions == "true") then
--skip the instructions
else
if (dtmf_digits and string.len(dtmf_digits) == 0) then
dtmf_digits = macro(session, "record_message", 1, 100);
end
end
--voicemail ivr options
if (session:ready()) then
if (dtmf_digits == nil) then
dtmf_digits = session:getDigits(max_digits, "#", 1000);
else
dtmf_digits = dtmf_digits .. session:getDigits(max_digits, "#", 1000);
end
end
if (dtmf_digits) then
if (string.len(dtmf_digits) > 0) then
if (direct_dial["enabled"] == "true") then
if (string.len(dtmf_digits) < max_digits) then
dtmf_digits = dtmf_digits .. session:getDigits(direct_dial["max_digits"], "#", 3000);
end
end
end
freeswitch.consoleLog("notice", "[voicemail] dtmf_digits: " .. string.sub(dtmf_digits, 0, 1) .. "\n");
if (dtmf_digits == "*") then
if (remote_access == "true") then
--check the voicemail password
check_password(voicemail_id, password_tries);
--send to the main menu
timeouts = 0;
main_menu();
else
--remote access is false
freeswitch.consoleLog("notice", "[voicemail] remote access is disabled.\n");
session:hangup();
end
elseif (string.sub(dtmf_digits, 0, 1) == "*") then
--do not allow dialing numbers prefixed with *
session:hangup();
else
--get the voicemail options
local sql = [[SELECT * FROM v_voicemail_options WHERE voicemail_uuid = :voicemail_uuid ORDER BY voicemail_option_order asc ]];
local params = {voicemail_uuid = voicemail_uuid};
if (debug["sql"]) then
freeswitch.consoleLog("notice", "[voicemail] SQL: " .. sql .. "; params:" .. json.encode(params) .. "\n");
end
count = 0;
dbh:query(sql, params, function(row)
--check for matching options
if (tonumber(row.voicemail_option_digits) ~= nil) then
row.voicemail_option_digits = "^"..row.voicemail_option_digits.."$";
end
if (api:execute("regex", "m:~"..dtmf_digits.."~"..row.voicemail_option_digits) == "true") then
if (row.voicemail_option_action == "menu-exec-app") then
--get the action and data
pos = string.find(row.voicemail_option_param, " ", 0, true);
action = string.sub( row.voicemail_option_param, 0, pos-1);
data = string.sub( row.voicemail_option_param, pos+1);
--check if the option uses a regex
regex = string.find(row.voicemail_option_digits, "(", 0, true);
if (regex) then
--get the regex result
result = trim(api:execute("regex", "m:~"..digits.."~"..row.voicemail_option_digits.."~$1"));
if (debug["regex"]) then
freeswitch.consoleLog("notice", "[voicemail] regex m:~"..digits.."~"..row.voicemail_option_digits.."~$1\n");
freeswitch.consoleLog("notice", "[voicemail] result: "..result.."\n");
end
--replace the $1 and the domain name
data = data:gsub("$1", result);
data = data:gsub("${domain_name}", domain_name);
end --if regex
end --if menu-exex-app
end --if regex match
--execute
if (action) then
if (string.len(action) > 0) then
--send to the log
if (debug["action"]) then
freeswitch.consoleLog("notice", "[voicemail] action: " .. action .. " data: ".. data .. "\n");
end
--run the action
session:execute(action, data);
end
end
--clear the variables
action = "";
data = "";
--inrement the option count
count = count + 1;
end); --end results
--direct dial
if (direct_dial["enabled"] == "true" and count == 0) then
dtmf_digits = dtmf_digits .. session:getDigits(direct_dial["max_digits"], "#", 5000);
session:transfer(dtmf_digits.." XML "..context);
end
end
end
end
end
end
end
--play the beep
dtmf_digits = '';
result = macro(session, "record_beep", 1, 100);
--start epoch
start_epoch = os.time();
-- syntax is session:recordFile(file_name, max_len_secs, silence_threshold, silence_secs)
silence_seconds = 5;
if (storage_path == "http_cache") then
result = session:recordFile(storage_path.."/"..voicemail_id.."/msg_"..uuid.."."..vm_message_ext, max_len_seconds, record_silence_threshold, silence_seconds);
session:execute("sleep", "5000");
else
mkdir(voicemail_dir.."/"..voicemail_id);
if (vm_message_ext == "mp3") then
shout_exists = trim(api:execute("module_exists", "mod_shout"));
if (shout_exists == "true" and transcribe_enabled == "false") or (shout_exists == "true" and transcribe_enabled == "true" and voicemail_transcription_enabled == "false") then
freeswitch.consoleLog("notice", "using mod_shout for mp3 encoding\n");
--record in mp3 directly
result = session:recordFile(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".mp3", max_len_seconds, record_silence_threshold, silence_seconds);
else
--create initial wav recording
result = session:recordFile(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".wav", max_len_seconds, record_silence_threshold, silence_seconds);
if (transcribe_enabled == "true" and voicemail_transcription_enabled == "true") then
transcription = transcribe(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".wav",settings,start_epoch);
end
--use lame to encode, if available
if (file_exists("/usr/bin/lame")) then
freeswitch.consoleLog("notice", "using lame for mp3 encoding\n");
--convert the wav to an mp3 (lame required)
resample = "/usr/bin/lame -b 32 --resample 8 -m s "..voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".wav "..voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".mp3";
session:execute("system", resample);
--delete the wav file, if mp3 exists
if (file_exists(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".mp3")) then
os.remove(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid..".wav");
else
vm_message_ext = "wav";
end
else
freeswitch.consoleLog("notice", "neither mod_shout or lame found, defaulting to wav\n");
end
end
else
result = session:recordFile(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid.."."..vm_message_ext, max_len_seconds, record_silence_threshold, silence_seconds);
transcription = transcribe(voicemail_dir.."/"..voicemail_id.."/msg_"..uuid.."."..vm_message_ext,settings,start_epoch);
end
end
end
--stop epoch
stop_epoch = os.time();
--calculate the message length
message_length = stop_epoch - start_epoch;
message_length_formatted = format_seconds(message_length);
--if the recording is below the minimal length then re-record the message
if (message_length > 2) then
--continue
else
--your recording is below the minimal acceptable length, please try again
dtmf_digits = '';
macro(session, "too_small", 1, 100);
timeouts = timeouts + 1;
if (timeouts < max_timeouts) then
record_message();
else
timeouts = 0;
record_menu("message", voicemail_dir.."/"..voicemail_id.."/msg_"..uuid.."."..vm_message_ext);
end
end
end
--instructions press 1 to listen to the recording, press 2 to save the recording, press 3 to re-record
--save the message
dtmf_digits = '';
macro(session, "message_saved", 1, 100, '');
macro(session, "goodbye", 1, 100, '');
--hangup the call
session:hangup();
else
timeouts = 0;
end
end
end
mingus
I'm sorry that didn't help. Rollback the changes.
Are you on a bare metal server? If not, who are you using for VM service?
mudasar321
84
@mingus I tested on two different machines with freeswitch version 1.6.20 and has same issue on both. Also I tested with freeswitch version 1.8.5 it works well. So it seems issue is with freeswitch version. Is there a way to get this fixed on version 1.6.20?
566
Absolutely not, it has been end of life for a couple of years now, it will never see another commit.
