SOLVED Gateway not starting in FusionPBX
Husnain Taseer
15
Hi Folks!
I have recently installed FusionPBX on a fresh Debian 8 system. I have also created few domains on the PBX and create extensions for each domain. Internal calls are working perfectly but I am not able to make external PSTN calls. I have added a gateway using information i got from my provider but when I click on "start" the page reloads and nothing happens the status of gateway is still stopped.
When I connect freeswitch using fs_cli, I can't see any gateway configured there. Command "sofia status gateway" showing 0 gateways configured. Any advice/suggestion will be highly appreciated.
Looking forward for your answers.
Regards,
Husnain Taseer
VoIP Professional
Hi Folks!
Regards,
Husnain Taseer
VoIP Professional
This would indicate, usually, a misconfiguration in the gateway. Have you put anything in the hostname field by any chance? That should be empty. If you could post a screenshot of the gateway config, that would be handy.
Husnain Taseer
15
Hi Digitaldaz,
Please find the attached screenshot, when I use same configuration on a sip phone it works perfectly. Domain in screenshot (sip.provider.net) is not actual its replaced. But fields are filled as shown in the image.
Husnain Taseer
15
Hi Digitaldaz,
Thank you (y). After removing hostname field from the configuration its working now.
