Goodnight
I am very grateful for the support of the people who are in this forum because thanks to it and managed to put in a test stage a pbx for the institution where I work, it will have to support when it is in production 1000 extensions and 30 outgbound calls concurrent As maximum, for it is using a physical server with two processors and 4 gb ram with a pure aterisk and a TE210p digium card with echo canceller that will serve as gateway with the PSTN, and a virtual server with two cpu and four gb of For the fusionpbx.
The question would be:
Will that hardware be enough to support the above?
Any way to directly connect the digium card to the server with fusionpbx?
