Help with night mode (call flow) toggle on side car. (solved)
Chidado
50
Hello all,
I am having an issue with night mode toggle on the side car of my cisco/yealink phones. Once setup the button changes to red, after a few minutes it changes back to green but night mode is still active.
Thanks in advance,
Chidado
moteus
13
You have to run one of service to keep its state in sync. Checkout lua.conf.xml file.
Basically there 2 strategy. 1 - resend state each X seconds (call_flow_monitor.lua).
2 - respond to phones SUBSCRIBE messages (call_flow_subscribe.lua).
mfelli
16
Thanks moteus that worked! I had to run 2 commands using Advanced, Command menu before I started seeing it work:
reloadxml
luarun /usr/share/freeswitch/scripts/call_flow_subscribe.lua
Now when my yealinks refresh their BLF subscriptions it updates. I do still have to figure out why it clears it first though, which is odd. But will worry about that later!
[update] Omg, I dunno how I missed this. But call flows should start with "flow+" then the feature code example: flow+*7003
The phone no longer clears it, and no longer wakes up every time it refreshes subscribe.
Reactions: Chidado
