How to make sip extension use specific sip gateway(s)?
yhbilisim
Hello
example:
ext 700 use gateway1
ext 701 use gateway2
566
You cannot do it this way. You can however add a condition to an outbound route that ties down to a single/group/whatever of phones.
JUst create seperate outbound routes that only have the gateway you want and add a condition that matches only the extensions you want to use it.
yhbilisim
Hello
How can I do that?
roger_roger
198
19
Create your 2 different gateways
Create an outbound route with this as the first condition:
condition ${outbound_caller_id_number} ^(700)$
. blah
. blah
. blah
action bridge gateway_name
repeat for 701
yhbilisim
. blah
. blah
. blah
repeat for 701
Hello
Thank you for being helpful.
