INBOUND route configuration help please
Spin1234
simple help, will gladly pay but need proof youre competent please
simple inbound help, the rest works
thank you
mcs3ss2
258
27
AU
share your problem, error will try to help here for free
usual inbound call problems are caused by number formatting
carrier may be sending calls to you on one format and you are handing in other format
What format is your carrier sending you calls?
Spin1234
Hello, thanks for helping
I'm the carrier
I entered the number simply, could it be I'm using a softphone and it's my softphone, the server is in a data center so there will be mostly remote extensions
I have no issue sharing login or coordinating an anydesk
mcs3ss2
258
27
AU
Appologise, Not being rude, if you are a carrier you wont be hovering here
Let me rephrase my question
How is your upstream provider sending you the number / sip invite? E.64 or National format? What format is your FusionPBX receiving the invite?
Can you share snGrep screenshot?
