incoming calls stop working after 2 minutes -- sip option
wouam31
73
Hello everyone,
I have a little problem with my trunk.
Outgoing calls are OK.
Incoming calls are OK for about 2 minutes, then I have nothing (on fusionpbx).
I tested the trunk on another machine, no problems.
In Expire Seconds I put 300 as recommended by the vendor.
On the other hand, he tells me about SIP OPTION which must be set to 120.
This is the periodic timer used to send a SIP “OPTION” message to the provider. It can be used to maintain the router bindings opened for receiving incoming requests.
How can I do? Or am I mistaken?
Gateways -> Edit Gateway -> Advanced -> Ping = 120
If you are behind NAT, it might be worth investigating your UDP timeout configuration on the device carrying out NAT (router, firewall, etc). Some devices keep an incredibly low UDP timeout as a default which will close a SIP socket quite early.
wouam31
73
Hi! thank you for the information, I test and I will make a return, if it solves my problem
Fusionpbx is installed on a vps. The firewall is not activated. For the moment I am testing without security to avoid adding problems to fusionpbx.
wouam31
73
Hi! The ping option does not solve the problem, it goes well, my provider responds well to the ping, but incoming calls do not arrive after 2 min.
I tried to modify in the external profiles:
minimum-session-expires: 120
session timeout: 120
The problem persists.
wouam31
73
Hi, I just asked my supplier what problem he sees.
Their sbc sends well. I have nothing on my side.
It asks me to check my dialplan.
But calls do come in from time to time.
An idea? I am lost!
