is it right to clear RAM cache daily?
Mikeme
173
i set up cron to run # sync; echo 1 > /proc/sys/vm/drop_caches every day in midnight.
is it right to do it?
whut
185
17
As I understand it this will free up memory which would be good. But a caution of lower performance until the cache is rebuilt over time with frequently used data.
Dast
57
I would advise against this.
Linux likes to keep caches full to minimise disk reads, this is a good thing for performance. It will automatically optimise what to keep in the cache.
Unused RAM is wasted RAM.
What is your reason for wanting to free up memory?
Mikeme
173
Cache using more then 50% of ram.
I would like to have free ram for Fusionpbx calls.
Is there any option to limit the cache ram amount?
Dast
57
Are you currently having issues with calls due to running out of ram? How have you confirmed this?
