IVR CallerID Prefix Not Working
Robert Birch
111
I maybe doing something wrong, but I am trying to send a CallerID Prefix to an extension by setting the Caller ID Name Prefix option in the IVR page.
But it doesn't seem to get passed. If I check the call detail record, I don't see the prefix being added.
Am I missing something?
mudasar321
84
Hi, Did anyone get a change to take a look into this? It's not working. I'm at version 4.5.18.
Bifur
122
I added a prefix to a test IVR and it did not prepend the caller id after choosing an option either. Is that the way it is suppose to work?
Robert Birch
111
The only way I could get it to work, was to go to DialPlan Manager and select the entry for the IVR in question.
I then had to click the XML button and add the following line:
<action application="set" data="effective_caller_id_name=ENG#${caller_id_name}"/>
Where ENG is the prefix. Save it and it works. Issue is, if you modify the IVR, this addition will be lost, and you need to add the line in again.
This is on Fusion 4.4.8. I haven't tried/tested on 4.5 yet.
Bifur
122
For anyone else, I just tried this. It seems if you use a : (IE Test: ) as a prefix, then the prefix is not included. If I just did Test then the caller ID shows up Test#Caller ID info.
This is on 4.5
Xtc_Voip
15
My Prefix is showing twice Test# Test# 1234567890, any thoughts what would cause this ?
