ms teams kamailio and opensips
andycol
47
14
Both of them are giving me a headache with ssl certs
which ssl certs have you guys used to get it working?
as i keep getting
Sep 21 15:40:08 bitco-msteams /usr/sbin/kamailio[6896]: ERROR: tls [tls_util.h:42]: tls_err_ret(): TLS write:error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed
i am using a comodo ssl cert and a letsencrypt both give me the same
566
Letsencrypt, no problems whasoever, you using that dsiprouter as a base, if so his cacert.pem was bad, needed changing
Reactions: andycol
566
Yes, there is a tls.cfg
# This is the default server domain profile.
# Settings in this domain will be used for all incoming
# connections that do not match any other server
# domain in this configuration file.
# We do not enable anything else than TLSv1.2+
# over the public internet. Clients do not have
# to present client certificates by default.
[server:default]
method = TLSv1.2+
verify_certificate = yes
require_certificate = yes
private_key = /etc/dsiprouter/certs/dsiprouter.key
certificate = /etc/dsiprouter/certs/dsiprouter.crt
ca_list = /etc/dsiprouter/certs/cacert.pem
#crl = /etc/dsiprouter/certs/tls/crl.pem
# This is the default client domain profile.
# Settings in this domain will be used for all outgoing
# TLS connections that do not match any other
# client domain in this configuration file.
# We require that servers present valid certificate.
[client:default]
method = TLSv1.2+
# Other domain profiles may be added here
They are regular letsencrypt certs on mine
andycol
47
14
Thanks, at the risk of sounding retarded how did you get letsencrypt certs to be .crt and not .pem
robvandenbulk
82
[server:default]
method = TLSv1.2+
private_key = /etc/letsencrypt/live/sbc.name.berlin/privkey.pem
certificate = /etc/letsencrypt/live/sbc.name.berlin/fullchain.pem
ca_list = /etc/letsencrypt/live/sbc.name.berlin/bc2025.pem
server_name = sbc.name.berlin
[client:default]
method = TLSv1.2+
