Multi tenant question
Bifur
122
Is there any performance impact by having many 1-2 extension domains? Is it better to condense to as few as possible if the situation allowed?
Just want to get a better understanding on resource usage.
Is there any thing else to consider when using multi tenant?
Thank you!
377
I don't see it being a performance impact. The tenant/domain is just another dialplan context as far as FreeSWITCH is concerned. The single most important performance factor is making sure you can handle the number of SIP messages arriving at your system, this is likely to be the same for a given number of extensions irrespective of how they are split up across domains.
Reactions: Bifur
Bifur
122
Thank you. I thought that would be the case but I just wanted to ask in case I was overlooking something.
Just trying to make sure I understand so I can scale it properly.
Thank you!
