SOLVED Outbound Caller ID's and handset diversions?
Here's the situation. These are some standalone single user handsets, and as there's going to be a number of strange SIP devices on the end we can't rely on feature key sync for diverting. It's essentially a response to the PSTN shutdown in the UK
My problem however is when a Yealink deskphone enabled a forward all, when that call hits the PBX, it gets pushed to the Yealink who replies back with a 301 Redirect and the PBX then tries to forward the original callers number out the trunk as its own identity. This results in a failure as it triggers the anti-spoofing.
Does anyone know the method to set a diversion outbound call to the extensions outbound_caller_id number? I've been tweaking for hours with stuff like:
${caller_id_number}
${user_data ${username}@${domain} var outbound_caller_id_number}
It works when I set outbound_caller_id_number={EXTENSION NUMBER} for example: outbound_caller_id_number=01234567890 but this isn't dynamically changing to the extension who has forwarded it.
I can provide more info if this isn't clear.
Nevermind. It was simpler than I thought. All I had to do was export a new variable diversion_outbound_number=${dialed_extension} and use that in the outbound routes as my effective_caller_id_number.
There's me trying to complicate things by doing it in the one leg,
