Outbound Calls based on Whitelist, possible? Any input?
bdmonsey
146
Customer wants me to setup certain extensions ( I guess will go thru Toll Allow) to only be able to call the allowed numbers that we whitelist for them.
so for example if user 101 wants to call 888-888-1234 , it will check outbound route and if it's there it will go thru otherwise will play a message "Call not authorized"
Any input?
bdmonsey
146
Any input in this?
basically a dial plan that checks which extension is making call, blocks 3 digit extensions (to block off calling extension to extension) and then allows only calls that the phone number is in the dial plan.
^(0723151111|0723152222|0774828488|035585687|023136031|0772222444)
197
Your first message mentioned the solution. Toll_allow is the feature you are looking for.
On the restricted extensions, add something like "restricted" in toll_allow box.
Then edit your outbound routes to check for the toll_allow variable and act accordingly.
Toll_allow has been discussed many times here in the forums with exapmple dial plans.
