process cdr via post
<?xml version="1.0"?>
<cdr core-uuid="a0d99799-9c7e-4add-b4e0-0584d174a71f" switchname="ddh-fusion.dynamite.net.nz">
<channel_data>
<state>CS_REPORTING</state>
<direction>inbound</direction>
<state_number>11</state_number>
<flags>0=1;1=1;3=1;37=1;38=1;40=1;43=1;48=1;53=1;106=1;112=1;113=1;122=1</flags>
<caps>1=1;2=1;3=1;4=1;5=1;6=1</caps>
</channel_data>
<call-stats>
<audio>
<inbound>
<raw_bytes>35432</raw_bytes>
<media_bytes>35432</media_bytes>
<packet_count>206</packet_count>
<media_packet_count>206</media_packet_count>
<skip_packet_count>28</skip_packet_count>
<jitter_packet_count>0</jitter_packet_count>
<dtmf_packet_count>0</dtmf_packet_count>
<cng_packet_count>0</cng_packet_count>
<flush_packet_count>0</flush_packet_count>
<largest_jb_size>0</largest_jb_size>
<jitter_min_variance>0.03</jitter_min_variance>
<jitter_max_variance>46.17</jitter_max_variance>
<jitter_loss_rate>0.00</jitter_loss_rate>
<jitter_burst_rate>0.00</jitter_burst_rate>
<mean_interval>20.00</mean_interval>
<flaw_total>0</flaw_total>
<quality_percentage>100.00</quality_percentage>
<mos>4.50</mos>
</inbound>
<outbound>
<raw_bytes>38184</raw_bytes>
<media_bytes>38184</media_bytes>
<packet_count>222</packet_count>
<media_packet_count>222</media_packet_count>
<skip_packet_count>0</skip_packet_count>
<rtcp_packet_count>0</rtcp_packet_count>
<rtcp_octet_count>0</rtcp_octet_count>
</outbound>
</audio>
</call-stats>
<variables>
<uuid>4b8d7fbc-525b-4d1e-97b0-8999155aa1d4</uuid>
<session_id>1470</session_id>
<sip_from_user>601</sip_from_user>
<sip_from_port>6285</sip_from_port>
<sip_from_uri>601%40ddh.sip.dynamite.net.nz%3A6285</sip_from_uri>
<sip_from_host>ddh.sip.dynamite.net.nz</sip_from_host>
<video_media_flow>sendrecv</video_media_flow>
<channel_name>sofia/internal/601%40ddh.sip.dynamite.net.nz%3A6285</channel_name>
<ep_codec_string>CORE_PCM_MODULE.PCMU%408000h%4020i%4064000b,CORE_PCM_MODULE.PCMA%408000h%4020i%4064000b</ep_codec_string>
<sip_local_network_addr>103.16.181.236</sip_local_network_addr>
<sip_network_ip>203.118.151.209</sip_network_ip>
<sip_network_port>6285</sip_network_port>
<sip_invite_stamp>1518427053902148</sip_invite_stamp>
<sip_received_ip>203.118.151.209</sip_received_ip>
<sip_received_port>6285</sip_received_port>
<sip_via_protocol>udp</sip_via_protocol>
<sip_authorized>true</sip_authorized>
<Event-Name>REQUEST_PARAMS</Event-Name>
<Core-UUID>a0d99799-9c7e-4add-b4e0-0584d174a71f</Core-UUID>
<FreeSWITCH-Hostname>ddh-fusion.dynamite.net.nz</FreeSWITCH-Hostname>
<FreeSWITCH-Switchname>ddh-fusion.dynamite.net.nz</FreeSWITCH-Switchname>
<FreeSWITCH-IPv4>103.16.181.236</FreeSWITCH-IPv4>
<FreeSWITCH-IPv6>%3A%3A1</FreeSWITCH-IPv6>
<Event-Date-Local>2018-02-12%2022%3A17%3A33</Event-Date-Local>
<Event-Date-GMT>Mon,%2012%20Feb%202018%2009%3A17%3A33%20GMT</Event-Date-GMT>
<Event-Date-Timestamp>1518427053902148</Event-Date-Timestamp>
<Event-Calling-File>sofia.c</Event-Calling-File>
<Event-Calling-Function>sofia_handle_sip_i_invite</Event-Calling-Function>
<Event-Calling-Line-Number>10096</Event-Calling-Line-Number>
<Event-Sequence>1456428</Event-Sequence>
<sip_number_alias>601</sip_number_alias>
<sip_auth_username>601</sip_auth_username>
<sip_auth_realm>ddh.sip.dynamite.net.nz</sip_auth_realm>
<number_alias>601</number_alias>
<requested_user_name>601</requested_user_name>
<requested_domain_name>ddh.sip.dynamite.net.nz</requested_domain_name>
<domain_uuid>13aa6a1c-5a03-4391-8a42-6aa16211ac4f</domain_uuid>
<extension_uuid>5aa51c36-c0dc-44fa-9e8d-a34dea07a1ab</extension_uuid>
<call_timeout>30</call_timeout>
<caller_id_name>601</caller_id_name>
<caller_id_number>601</caller_id_number>
<presence_id>601%40ddh.sip.dynamite.net.nz</presence_id>
<call_group>1</call_group>
<call_screen_enabled>false</call_screen_enabled>
<hold_music>local_stream%3A//default</hold_music>
<accountcode>ddh.sip.dynamite.net.nz</accountcode>
<user_context>ddh.sip.dynamite.net.nz</user_context>
<missed_call_app>email</missed_call_app>
<missed_call_data>fraser%40dynamite.net.nz</missed_call_data>
<directory-visible>true</directory-visible>
<directory-exten-visible>true</directory-exten-visible>
<limit_max>5</limit_max>
<limit_destination>error/user_busy</limit_destination>
<forward_all_enabled>false</forward_all_enabled>
<forward_all_destination>611</forward_all_destination>
<forward_busy_enabled>false</forward_busy_enabled>
<forward_no_answer_enabled>false</forward_no_answer_enabled>
<forward_user_not_registered_enabled>false</forward_user_not_registered_enabled>
<do_not_disturb>false</do_not_disturb>
<record_stereo>true</record_stereo>
<transfer_fallback_extension>operator</transfer_fallback_extension>
<user_name>601</user_name>
<domain_name>ddh.sip.dynamite.net.nz</domain_name>
<sip_from_user_stripped>601</sip_from_user_stripped>
<sofia_profile_name>internal</sofia_profile_name>
<recovery_profile_name>internal</recovery_profile_name>
<sip_allow>INVITE,%20ACK,%20OPTIONS,%20BYE,%20CANCEL,%20REFER,%20NOTIFY,%20INFO,%20PRACK,%20UPDATE,%20MESSAGE</sip_allow>
<sip_req_params>user%3Dphone</sip_req_params>
<sip_req_user>0800000000</sip_req_user>
<sip_req_port>6285</sip_req_port>
<sip_req_uri>0800000000%40ddh.sip.dynamite.net.nz%3A6285</sip_req_uri>
<sip_req_host>ddh.sip.dynamite.net.nz</sip_req_host>
<sip_to_params>user%3Dphone</sip_to_params>
<sip_to_user>0800000000</sip_to_user>
<sip_to_port>6285</sip_to_port>
<sip_to_uri>0800000000%40ddh.sip.dynamite.net.nz%3A6285</sip_to_uri>
<sip_to_host>ddh.sip.dynamite.net.nz</sip_to_host>
<sip_contact_user>601</sip_contact_user>
<sip_contact_port>6285</sip_contact_port>
<sip_contact_uri>601%40203.118.151.209%3A6285</sip_contact_uri>
<sip_contact_host>203.118.151.209</sip_contact_host>
<sip_via_host>192.168.45.102</sip_via_host>
<sip_via_port>6285</sip_via_port>
<sip_via_rport>6285</sip_via_rport>
<max_forwards>70</max_forwards>
<sip_h_P-Early-Media>supported</sip_h_P-Early-Media>
<switch_r_sdp>v%3D0%0D%0Ao%3D601%20270067148%202692212431%20IN%20IP4%20192.168.45.102%0D%0As%3DA%20conversation%0D%0Ac%3DIN%20IP4%20192.168.45.102%0D%0At%3D0%200%0D%0Am%3Daudio%2010204%20RTP/AVP%209%200%208%2018%202%204%20101%0D%0Aa%3Drtpmap%3A9%20G722/8000%0D%0Aa%3Drtpmap%3A0%20PCMU/8000%0D%0Aa%3Drtpmap%3A8%20PCMA/8000%0D%0Aa%3Drtpmap%3A18%20G729/8000%0D%0Aa%3Dfmtp%3A18%20annexb%3Dno%0D%0Aa%3Drtpmap%3A2%20G726-32/8000%0D%0Aa%3Drtpmap%3A4%20G723/8000%0D%0Aa%3Dfmtp%3A4%20bitrate%3D6.3%0D%0Aa%3Drtpmap%3A101%20telephone-event/8000%0D%0Aa%3Dfmtp%3A101%200-15%0D%0A</switch_r_sdp>
<rtp_use_codec_string>PCMU,PCMA,GSM</rtp_use_codec_string>
<audio_media_flow>sendrecv</audio_media_flow>
<rtp_audio_recv_pt>0</rtp_audio_recv_pt>
<rtp_use_codec_name>PCMU</rtp_use_codec_name>
<rtp_use_codec_rate>8000</rtp_use_codec_rate>
<rtp_use_codec_ptime>20</rtp_use_codec_ptime>
<rtp_use_codec_channels>1</rtp_use_codec_channels>
<rtp_last_audio_codec_string>PCMU%408000h%4020i%401c</rtp_last_audio_codec_string>
<read_codec>PCMU</read_codec>
<original_read_codec>PCMU</original_read_codec>
<read_rate>8000</read_rate>
<original_read_rate>8000</original_read_rate>
<write_codec>PCMU</write_codec>
<write_rate>8000</write_rate>
<dtmf_type>rfc2833</dtmf_type>
<original_caller_id_name>Dynamite</original_caller_id_name>
<cidlookup_source>UNKNOWN</cidlookup_source>
<cidlookup_area>UNKNOWN</cidlookup_area>
<user_exists>false</user_exists>
<601>0601</601>
<from_user_exists>true</from_user_exists>
<outbound_caller_id_name>Dynamite%20IT%20Solutions</outbound_caller_id_name>
<outbound_caller_id_number>049778255</outbound_caller_id_number>
<lca>04</lca>
<dialed_number>0800000000</dialed_number>
<DP_MATCH>0800000000</DP_MATCH>
<sip_h_X-accountcode>ddh.sip.dynamite.net.nz</sip_h_X-accountcode>
<hangup_after_bridge>true</hangup_after_bridge>
<effective_caller_id_name>Dynamite%20IT%20Solutions</effective_caller_id_name>
<effective_caller_id_number>049778255</effective_caller_id_number>
<inherit_codec>true</inherit_codec>
<ignore_display_updates>true</ignore_display_updates>
<callee_id_number>0800000000</callee_id_number>
<continue_on_fail>true</continue_on_fail>
<call_uuid>4b8d7fbc-525b-4d1e-97b0-8999155aa1d4</call_uuid>
<call_direction>local</call_direction>
<origination_callee_id_name>0800000000</origination_callee_id_name>
<export_vars>domain_name,origination_callee_id_name</export_vars>
<RFC2822_DATE>Mon,%2012%20Feb%202018%2022%3A17%3A35%20%2B1300</RFC2822_DATE>
<current_application_data>sofia/gateway/e3d7268e-85d8-4fd0-ae62-43c3124db15f/0800000000</current_application_data>
<current_application>bridge</current_application>
<originated_legs>cf829d7d-a547-4005-9da3-b742943ae245%3B0800000000%3B0800000000</originated_legs>
<switch_m_sdp>v%3D0%0D%0Ao%3DFreeSWITCH%201518402865%201518402866%20IN%20IP4%20114.23.6.182%0D%0As%3DFreeSWITCH%0D%0Ac%3DIN%20IP4%20114.23.6.182%0D%0At%3D0%200%0D%0Am%3Daudio%2024192%20RTP/AVP%200%20101%2013%0D%0Aa%3Drtpmap%3A0%20PCMU/8000%0D%0Aa%3Drtpmap%3A101%20telephone-event/8000%0D%0Aa%3Dfmtp%3A101%200-16%0D%0Aa%3Drtpmap%3A13%20CN/8000%0D%0Aa%3Dptime%3A20%0D%0A</switch_m_sdp>
<local_media_ip>103.16.181.236</local_media_ip>
<local_media_port>26292</local_media_port>
<advertised_media_ip>103.16.181.236</advertised_media_ip>
<rtp_use_timer_name>soft</rtp_use_timer_name>
<rtp_use_pt>0</rtp_use_pt>
<rtp_use_ssrc>1518585133</rtp_use_ssrc>
<rtp_2833_send_payload>101</rtp_2833_send_payload>
<rtp_2833_recv_payload>101</rtp_2833_recv_payload>
<remote_media_ip>192.168.45.102</remote_media_ip>
<remote_media_port>10204</remote_media_port>
<originate_disposition>SUCCESS</originate_disposition>
<DIALSTATUS>SUCCESS</DIALSTATUS>
<originate_causes>cf829d7d-a547-4005-9da3-b742943ae245%3BNONE</originate_causes>
<last_bridge_to>cf829d7d-a547-4005-9da3-b742943ae245</last_bridge_to>
<bridge_channel>sofia/external/0800000000</bridge_channel>
<bridge_uuid>cf829d7d-a547-4005-9da3-b742943ae245</bridge_uuid>
<signal_bond>cf829d7d-a547-4005-9da3-b742943ae245</signal_bond>
<remote_audio_ip_reported>192.168.45.102</remote_audio_ip_reported>
<remote_audio_ip>203.118.151.209</remote_audio_ip>
<remote_audio_port_reported>10204</remote_audio_port_reported>
<remote_audio_port>10204</remote_audio_port>
<rtp_auto_adjust_audio>true</rtp_auto_adjust_audio>
<rtp_local_sdp_str>v%3D0%0D%0Ao%3DFreeSWITCH%201518400765%201518400767%20IN%20IP4%20103.16.181.236%0D%0As%3DFreeSWITCH%0D%0Ac%3DIN%20IP4%20103.16.181.236%0D%0At%3D0%200%0D%0Am%3Daudio%2026292%20RTP/AVP%200%20101%0D%0Aa%3Drtpmap%3A0%20PCMU/8000%0D%0Aa%3Drtpmap%3A101%20telephone-event/8000%0D%0Aa%3Dfmtp%3A101%200-16%0D%0Aa%3Dptime%3A20%0D%0Aa%3Dsendrecv%0D%0A</rtp_local_sdp_str>
<sip_nat_detected>true</sip_nat_detected>
<endpoint_disposition>ANSWER</endpoint_disposition>
<sip_to_tag>c5D8rQUtXB69S</sip_to_tag>
<sip_from_tag>428225103</sip_from_tag>
<sip_cseq>2</sip_cseq>
<sip_call_id>76571645330167-9698802920684%40203.118.151.209</sip_call_id>
<sip_full_via>SIP/2.0/UDP%20192.168.45.102%3A6285%3Bbranch%3Dz9hG4bK1143179082488610911%3Breceived%3D203.118.151.209</sip_full_via>
<sip_from_display>Dynamite</sip_from_display>
<sip_full_from>Dynamite%20%3Csip%3A601%40ddh.sip.dynamite.net.nz%3A6285%3E%3Btag%3D428225103</sip_full_from>
<sip_to_display>0800000000</sip_to_display>
<sip_full_to>%220800000000%22%20%3Csip%3A0800000000%40ddh.sip.dynamite.net.nz%3A6285%3Buser%3Dphone%3E%3Btag%3Dc5D8rQUtXB69S</sip_full_to>
<last_sent_callee_id_name>64800000000</last_sent_callee_id_name>
<last_sent_callee_id_number>64800000000</last_sent_callee_id_number>
<sip_term_status>200</sip_term_status>
<proto_specific_hangup_cause>sip%3A200</proto_specific_hangup_cause>
<sip_term_cause>16</sip_term_cause>
<last_bridge_role>originator</last_bridge_role>
<sip_user_agent>Fanvil%20X5%201.4.0.2001</sip_user_agent>
<sip_hangup_disposition>recv_bye</sip_hangup_disposition>
<bridge_hangup_cause>NORMAL_CLEARING</bridge_hangup_cause>
<hangup_cause>NORMAL_CLEARING</hangup_cause>
<hangup_cause_q850>16</hangup_cause_q850>
<digits_dialed>none</digits_dialed>
<start_stamp>2018-02-12%2022%3A17%3A33</start_stamp>
<profile_start_stamp>2018-02-12%2022%3A17%3A33</profile_start_stamp>
<answer_stamp>2018-02-12%2022%3A17%3A38</answer_stamp>
<bridge_stamp>2018-02-12%2022%3A17%3A37</bridge_stamp>
<progress_media_stamp>2018-02-12%2022%3A17%3A37</progress_media_stamp>
<end_stamp>2018-02-12%2022%3A17%3A41</end_stamp>
<start_epoch>1518427053</start_epoch>
<start_uepoch>1518427053962128</start_uepoch>
<profile_start_epoch>1518427053</profile_start_epoch>
<profile_start_uepoch>1518427053962128</profile_start_uepoch>
<answer_epoch>1518427058</answer_epoch>
<answer_uepoch>1518427058262135</answer_uepoch>
<bridge_epoch>1518427057</bridge_epoch>
<bridge_uepoch>1518427057262114</bridge_uepoch>
<last_hold_epoch>0</last_hold_epoch>
<last_hold_uepoch>0</last_hold_uepoch>
<hold_accum_seconds>0</hold_accum_seconds>
<hold_accum_usec>0</hold_accum_usec>
<hold_accum_ms>0</hold_accum_ms>
<resurrect_epoch>0</resurrect_epoch>
<resurrect_uepoch>0</resurrect_uepoch>
<progress_epoch>0</progress_epoch>
<progress_uepoch>0</progress_uepoch>
<progress_media_epoch>1518427057</progress_media_epoch>
<progress_media_uepoch>1518427057262114</progress_media_uepoch>
<end_epoch>1518427061</end_epoch>
<end_uepoch>1518427061922126</end_uepoch>
<last_app>bridge</last_app>
<last_arg>sofia/gateway/e3d7268e-85d8-4fd0-ae62-43c3124db15f/0800000000</last_arg>
<caller_id>%22UNKNOWN%22%20%3C601%3E</caller_id>
<duration>8</duration>
<billsec>3</billsec>
<progresssec>0</progresssec>
<answersec>5</answersec>
<waitsec>4</waitsec>
<progress_mediasec>4</progress_mediasec>
<flow_billsec>8</flow_billsec>
<mduration>7960</mduration>
<billmsec>3660</billmsec>
<progressmsec>0</progressmsec>
<answermsec>4300</answermsec>
<waitmsec>3300</waitmsec>
<progress_mediamsec>3300</progress_mediamsec>
<flow_billmsec>7960</flow_billmsec>
<uduration>7959998</uduration>
<billusec>3659991</billusec>
<progressusec>0</progressusec>
<answerusec>4300007</answerusec>
<waitusec>3299986</waitusec>
<progress_mediausec>3299986</progress_mediausec>
<flow_billusec>7959998</flow_billusec>
<rtp_audio_in_raw_bytes>35432</rtp_audio_in_raw_bytes>
<rtp_audio_in_media_bytes>35432</rtp_audio_in_media_bytes>
<rtp_audio_in_packet_count>206</rtp_audio_in_packet_count>
<rtp_audio_in_media_packet_count>206</rtp_audio_in_media_packet_count>
<rtp_audio_in_skip_packet_count>28</rtp_audio_in_skip_packet_count>
<rtp_audio_in_jitter_packet_count>0</rtp_audio_in_jitter_packet_count>
<rtp_audio_in_dtmf_packet_count>0</rtp_audio_in_dtmf_packet_count>
<rtp_audio_in_cng_packet_count>0</rtp_audio_in_cng_packet_count>
<rtp_audio_in_flush_packet_count>0</rtp_audio_in_flush_packet_count>
<rtp_audio_in_largest_jb_size>0</rtp_audio_in_largest_jb_size>
<rtp_audio_in_jitter_min_variance>0.03</rtp_audio_in_jitter_min_variance>
<rtp_audio_in_jitter_max_variance>46.17</rtp_audio_in_jitter_max_variance>
<rtp_audio_in_jitter_loss_rate>0.00</rtp_audio_in_jitter_loss_rate>
<rtp_audio_in_jitter_burst_rate>0.00</rtp_audio_in_jitter_burst_rate>
<rtp_audio_in_mean_interval>20.00</rtp_audio_in_mean_interval>
<rtp_audio_in_flaw_total>0</rtp_audio_in_flaw_total>
<rtp_audio_in_quality_percentage>100.00</rtp_audio_in_quality_percentage>
<rtp_audio_in_mos>4.50</rtp_audio_in_mos>
<rtp_audio_out_raw_bytes>38184</rtp_audio_out_raw_bytes>
<rtp_audio_out_media_bytes>38184</rtp_audio_out_media_bytes>
<rtp_audio_out_packet_count>222</rtp_audio_out_packet_count>
<rtp_audio_out_media_packet_count>222</rtp_audio_out_media_packet_count>
<rtp_audio_out_skip_packet_count>0</rtp_audio_out_skip_packet_count>
<rtp_audio_out_dtmf_packet_count>0</rtp_audio_out_dtmf_packet_count>
<rtp_audio_out_cng_packet_count>0</rtp_audio_out_cng_packet_count>
<rtp_audio_rtcp_packet_count>0</rtp_audio_rtcp_packet_count>
<rtp_audio_rtcp_octet_count>0</rtp_audio_rtcp_octet_count>
</variables>
<app_log>
<application app_name="cidlookup" app_data="0601" app_stamp="1518427053986184"></application>
<application app_name="set" app_data="user_exists=false" app_stamp="1518427055619675"></application>
<application app_name="set" app_data="effective_caller_id_name=0601" app_stamp="1518427055620159"></application>
<application app_name="set" app_data="effective_caller_id_number=0601" app_stamp="1518427055620379"></application>
<application app_name="set" app_data="601=0601" app_stamp="1518427055620672"></application>
<application app_name="set" app_data="user_record=" app_stamp="1518427055629816"></application>
<application app_name="set" app_data="from_user_exists=true" app_stamp="1518427055632851"></application>
<application app_name="set" app_data="from_user_record=" app_stamp="1518427055635527"></application>
<application app_name="set" app_data="outbound_caller_id_name=Dynamite IT Solutions" app_stamp="1518427055635984"></application>
<application app_name="set" app_data="outbound_caller_id_number=049778255" app_stamp="1518427055636181"></application>
<application app_name="set" app_data="lca=04" app_stamp="1518427055636377"></application>
<application app_name="set" app_data="dialed_number=0800000000" app_stamp="1518427055636771"></application>
<application app_name="set" app_data="sip_h_X-accountcode=ddh.sip.dynamite.net.nz" app_stamp="1518427055638394"></application>
<application app_name="set" app_data="call_direction=outbound" app_stamp="1518427055638644"></application>
<application app_name="set" app_data="hangup_after_bridge=true" app_stamp="1518427055638902"></application>
<application app_name="set" app_data="effective_caller_id_name=Dynamite IT Solutions" app_stamp="1518427055639125"></application>
<application app_name="set" app_data="effective_caller_id_number=049778255" app_stamp="1518427055639351"></application>
<application app_name="set" app_data="inherit_codec=true" app_stamp="1518427055639569"></application>
<application app_name="set" app_data="ignore_display_updates=true" app_stamp="1518427055639785"></application>
<application app_name="set" app_data="callee_id_number=0800000000" app_stamp="1518427055640002"></application>
<application app_name="set" app_data="continue_on_fail=true" app_stamp="1518427055640234"></application>
<application app_name="set" app_data="call_direction=local" app_stamp="1518427055640738"></application>
<application app_name="export" app_data="origination_callee_id_name=0800000000" app_stamp="1518427055640952"></application>
<application app_name="set" app_data="RFC2822_DATE=Mon, 12 Feb 2018 22:17:35 +1300" app_stamp="1518427055641200"></application>
<application app_name="hash" app_data="insert/ddh.sip.dynamite.net.nz-last_dial/601/0800000000" app_stamp="1518427055641418"></application>
<application app_name="eval" app_data="not_secure" app_stamp="1518427055641661"></application>
<application app_name="bridge" app_data="sofia/gateway/e3d7268e-85d8-4fd0-ae62-43c3124db15f/0800000000" app_stamp="1518427055641900"></application>
</app_log>
<callflow dialplan="XML" unique-id="8dd16e5c-5379-472e-a526-31316a65f394" profile_index="1">
<extension name="Global-Contact-Lookup" number="0800000000">
<application app_name="set" app_data="call_direction=local"></application>
<application app_name="export" app_data="origination_callee_id_name=${destination_number}"></application>
<application app_name="set" app_data="RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)}"></application>
<application app_name="hash" app_data="insert/${domain_name}-last_dial/${caller_id_number}/${destination_number}"></application>
<application app_name="eval" app_data="not_secure"></application>
<application app_name="bridge" app_data="sofia/gateway/e3d7268e-85d8-4fd0-ae62-43c3124db15f/${dialed_number}"></application>
</extension>
<caller_profile>
<username>601</username>
<dialplan>XML</dialplan>
<caller_id_name>UNKNOWN</caller_id_name>
<callee_id_name>64800000000</callee_id_name>
<callee_id_number>64800000000</callee_id_number>
<ani>601</ani>
<aniii></aniii>
<network_addr>203.118.151.209</network_addr>
<rdnis></rdnis>
<destination_number>0800000000</destination_number>
<source>mod_sofia</source>
<context>ddh.sip.dynamite.net.nz</context>
<chan_name>sofia/internal/601@ddh.sip.dynamite.net.nz:6285</chan_name>
<origination>
<origination_caller_profile>
<caller_id_name>Dynamite IT Solutions</caller_id_name>
<caller_id_number>049778255</caller_id_number>
<callee_id_name>Outbound Call</callee_id_name>
<ani>601</ani>
<aniii></aniii>
<rdnis></rdnis>
<uuid>cf829d7d-a547-4005-9da3-b742943ae245</uuid>
<chan_name>sofia/external/0800000000</chan_name>
</origination_caller_profile>
</origination>
<originatee>
<originatee_caller_profile>
<ani>601</ani>
<aniii></aniii>
<network_addr>114.23.6.180</network_addr>
<rdnis></rdnis>
</originatee_caller_profile>
</originatee>
</caller_profile>
<times>
<created_time>1518427053962128</created_time>
<profile_created_time>1518427053962128</profile_created_time>
<progress_time>0</progress_time>
<progress_media_time>1518427057262114</progress_media_time>
<answered_time>1518427058262135</answered_time>
<bridged_time>1518427057262114</bridged_time>
<last_hold_time>0</last_hold_time>
<hold_accum_time>0</hold_accum_time>
<hangup_time>1518427061922126</hangup_time>
<resurrect_time>0</resurrect_time>
<transfer_time>0</transfer_time>
</times>
</callflow>
</cdr>
xml load done
domain_name is ``; domain_uuid is ''
0 inserts in: 0.00000 seconds.
Other processing time: 0.00240 seconds.
