Outbound in Destination Dropdown
Ankit
i m using 4.3.2 fusion PBX version.
When i tried to add inbound routes it's successfully added .but when i click on drop down on type there is 1 more option "outbound" what is the used of it? in fusion PBX is it useful for adding outbound routes.
Because it's make me confusing.
The outbound route option is for numbers your forwarding too,
so there are 2 ways of doing this
in Ring groups you can turn on forward and add a number - this is good for temp forwarding
or
You can add an outbound destination and configure the inbound destination to action the outbound destination - better for permanent forwarding
so call flow would look like this
Temp Forwarding
DDI ( Inbound Destination) > Ring Group > Forward enabled to ************
Permanant Forward
DDI ( Inbound Destination) > *********** ( Outbound Destination)
Hope this help
Matt
Hi Matthew,
I've created an inbound destination pointing to an outbound destination. Call comes in on inbound destination but, after that, I've a trasfer on public context and outbound destination fails. How should we set inbound and aoutbound destinations?
Thanks.
Chris
