SOLVED PR #6342 erroneous -- DND for Yealink
a_k
The pull request https://github.com/fusionpbx/fusionpbx/pull/6342/commits/0d9cd7f45942af49753d4592e2bfb174f7f8f3bd contains a syntax error that breaks fusionpbx:
The last line ($y++) misses a semicolon which breaks the web interface in several parts and leads to the following error:
PHP Parse error: syntax error, unexpected '$apps' (T_VARIABLE) in /var/www/fusionpbx/app/yealink/app_config.php on line 1501
After fixing the syntax error, all the database upgrades have to be done (again) because they failed during the inital update.
gflow
263
I submitted another pull request about 10min after that was accepted, I noticed that as well after the upgrade
Reactions: a_k
