ran update on 4.5.12 via web gui, no more web
s2svoip
259
I went to run a source code and schema update via the webgui on my dev install 4.5.12, and it just went to a PHP error page, I did not get a screen grab of the error but right after this, I just got a HTTP ERROR 500 when trying to access the web gui. was a bit stumped at what to do when you cant get any kind of response at this point. I rolled back to my last snapshot and was back up in a few mins but wondering how to troubleshoot this.
freeswitch was still running and calls looked to be working so I think it was just the web interface aspect. I have updated this install before via the web, so its odd
anyideas?
markjcrane
453
162
If you run Advanced -> Upgrade -> Source or when using git pull.
You may see the following symptoms.
Browser Symptoms
  • The code will error and you will see a blank page
    • The merge conflict breaks the syntax and result is the blank page.
Console symptoms
You may see this just after running a git pull from /var/www/fusionpbx
  • CONFLICT (content): Merge conflict
The following will fix this issue.
cp -R /var/www/fusionpbx /var/www/fusionpbx-20200327
cd /var/www/fusionpbx
git fetch origin
git reset --hard origin/master
git pull
chown -R www-data:www-data /var/www/fusionpbx
WARNING: This will work for most people. Un-tracked files should be safe. However if you manage your own customization's for files tracked by Git you will likely need to do more to fix this issue.
Reactions: s2svoip
s2svoip
259
thanks for the reply Mark, i did not actually get any kind of fusion generated error page, it went to a white page with a php error at the top, then the entire web interface would no longer work. I have updated this install before via the web GUI, and I resolved any conflicts for that to work so figured it would be fine this time. I can try doing the update once more and I will screen shot what I see this time
s2svoip
259
So I ran it once more, and it just went straight to the HTTP ERROR 500 page and no more web interface. I tried your steps above and it brought it back, it had error source update failed at the top, but I see in the dashboard its reporting 4.5.13
re ran the update via the web now and it says up-to-date, so that sorted it, cheers Mark!
markjcrane
453
162
The answer is still the same I just need to add your symptom to the list. The git merge conflict adds characters to the files that break the syntax and throws and error and then you are getting a blank screen from it. You need to go to the command line and run the commands that I shared.
Reactions: s2svoip
topogigio
68
My problem was an ""expecting end of file in /var/www/fusionpbx/resources/php.php on line 27"" error after the upgrade. Solved with the suggested git reset, thanks
Andrew Perry
Just had a similar issue, upgrading from an install made in August 2019. After running the above resets of the git repo and going back to the upgrade page, this was displayed which I believe is the log of what went wrong, if this helps to avoid future problems. I then ran the schema and data type checks, which gave another set of messages I have put below, after this log.
From https://github.com/fusionpbx/fusionpbx
056ee9f10..32a979924 master -> origin/master
cd7e9d38b..cd644b223 4.4 -> origin/4.4
warning: Cannot merge binary files: app/contacts/resources/images/icon_gmaps.png (HEAD vs. 32a9799241a816b328b2c5922ef9ddd37481ab21)
Auto-merging themes/default/template.php
CONFLICT (content): Merge conflict in themes/default/template.php
Auto-merging themes/default/css.php
CONFLICT (add/add): Merge conflict in themes/default/css.php
Auto-merging themes/default/app_languages.php
CONFLICT (add/add): Merge conflict in themes/default/app_languages.php
Auto-merging themes/default/app_config.php
CONFLICT (add/add): Merge conflict in themes/default/app_config.php
Auto-merging resources/templates/provision/yealink/vp530/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/vp530/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t57w/y000000000097.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t57w/y000000000097.cfg
Auto-merging resources/templates/provision/yealink/t54w/y000000000096.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t54w/y000000000096.cfg
Auto-merging resources/templates/provision/yealink/t53w/y000000000095.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t53w/y000000000095.cfg
Auto-merging resources/templates/provision/yealink/t52s/y000000000074.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t52s/y000000000074.cfg
Auto-merging resources/templates/provision/yealink/t49g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t49g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t48s/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t48s/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t48s/y000000000065.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t48s/y000000000065.cfg
Auto-merging resources/templates/provision/yealink/t48g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t48g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t46s/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t46s/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t46s/y000000000066.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t46s/y000000000066.cfg
Auto-merging resources/templates/provision/yealink/t46g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t46g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t46g/y000000000028.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t46g/y000000000028.cfg
Auto-merging resources/templates/provision/yealink/t42s/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t42s/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t42s/y000000000067.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t42s/y000000000067.cfg
Auto-merging resources/templates/provision/yealink/t42g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t42g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t41s/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t41s/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t41s/y000000000068.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t41s/y000000000068.cfg
Auto-merging resources/templates/provision/yealink/t41p/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t41p/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t40p/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t40p/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t40g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t40g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t40g/y000000000076.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t40g/y000000000076.cfg
Auto-merging resources/templates/provision/yealink/t29g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t29g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t27p/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t27p/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t27g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t27g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t23p/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t23p/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t23g/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t23g/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/t21p/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/t21p/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/cp960/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/cp960/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/cp920/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/cp920/{$mac}.cfg
Auto-merging resources/templates/provision/yealink/cp860/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/yealink/cp860/{$mac}.cfg
Auto-merging resources/templates/provision/polycom/5.x/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/polycom/5.x/{$mac}.cfg
Auto-merging resources/templates/provision/polycom/4.x/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/polycom/4.x/{$mac}.cfg
Auto-merging resources/templates/provision/mitel/5340/MN_{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/mitel/5340/MN_{$mac}.cfg
Auto-merging resources/templates/provision/mitel/5330/MN_{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/mitel/5330/MN_{$mac}.cfg
Auto-merging resources/templates/provision/mitel/5324/MN_{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/mitel/5324/MN_{$mac}.cfg
Auto-merging resources/templates/provision/grandstream/ht818/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/ht818/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxw42xx/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxw42xx/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp2170/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp2170/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp2160/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp2160/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp2140/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp2140/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp2135/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp2135/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp2130/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp2130/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/gxp16xx/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/gxp16xx/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/grp26xx/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/grp26xx/{$mac}.xml
Auto-merging resources/templates/provision/grandstream/dp750/{$mac}.xml
CONFLICT (add/add): Merge conflict in resources/templates/provision/grandstream/dp750/{$mac}.xml
Auto-merging resources/templates/provision/fanvil/x6/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/fanvil/x6/{$mac}.cfg
Auto-merging resources/templates/provision/fanvil/x5s/{$mac}.cfg
CONFLICT (add/add): Merge conflict in resources/templates/provision/fanvil/x5s/{$mac}.cfg
Auto-merging resources/templates/conf/autoload_configs/switch.conf.xml
CONFLICT (add/add): Merge conflict in resources/templates/conf/autoload_configs/switch.conf.xml
Auto-merging resources/templates/conf/autoload_configs/fifo.conf.xml
CONFLICT (add/add): Merge conflict in resources/templates/conf/autoload_configs/fifo.conf.xml
CONFLICT (rename/delete): includes/templates/conf/autoload_configs/fax.conf.xml deleted in 32a9799241a816b328b2c5922ef9ddd37481ab21 and renamed to resources/templates/conf/autoload_configs/fax.conf.xml in HEAD. Version HEAD of resources/templates/conf/autoload_configs/fax.conf.xml left in tree.
Auto-merging resources/templates/conf/autoload_configs/conference.conf
CONFLICT (add/add): Merge conflict in resources/templates/conf/autoload_configs/conference.conf
Auto-merging resources/switch.php
CONFLICT (add/add): Merge conflict in resources/switch.php
Auto-merging resources/require.php
CONFLICT (add/add): Merge conflict in resources/require.php
Auto-merging resources/php.php
CONFLICT (add/add): Merge conflict in resources/php.php
Auto-merging resources/paging.php
CONFLICT (add/add): Merge conflict in resources/paging.php
Auto-merging resources/login.php
CONFLICT (add/add): Merge conflict in resources/login.php
Auto-merging resources/functions.php
CONFLICT (add/add): Merge conflict in resources/functions.php
Auto-merging resources/footer.php
CONFLICT (add/add): Merge conflict in resources/footer.php
Auto-merging resources/classes/token.php
CONFLICT (add/add): Merge conflict in resources/classes/token.php
Auto-merging resources/classes/modal.php
CONFLICT (add/add): Merge conflict in resources/classes/modal.php
Auto-merging resources/classes/menu.php
CONFLICT (add/add): Merge conflict in resources/classes/menu.php
Auto-merging resources/classes/domains.php
CONFLICT (add/add): Merge conflict in resources/classes/domains.php
Auto-merging resources/classes/database.php
CONFLICT (add/add): Merge conflict in resources/classes/database.php
Auto-merging resources/check_auth.php
CONFLICT (add/add): Merge conflict in resources/check_auth.php
Auto-merging resources/app_languages.php
CONFLICT (add/add): Merge conflict in resources/app_languages.php
Auto-merging core/users/users.php
CONFLICT (add/add): Merge conflict in core/users/users.php
Auto-merging core/users/user_edit.php
CONFLICT (add/add): Merge conflict in core/users/user_edit.php
Auto-merging core/users/app_menu.php
CONFLICT (add/add): Merge conflict in core/users/app_menu.php
Auto-merging core/users/app_languages.php
CONFLICT (add/add): Merge conflict in core/users/app_languages.php
Auto-merging core/users/app_config.php
CONFLICT (content): Merge conflict in core/users/app_config.php
Auto-merging core/user_settings/user_settings.php
CONFLICT (add/add): Merge conflict in core/user_settings/user_settings.php
Auto-merging core/user_settings/user_setting_edit.php
CONFLICT (add/add): Merge conflict in core/user_settings/user_setting_edit.php
Auto-merging core/user_settings/user_dashboard.php
CONFLICT (add/add): Merge conflict in core/user_settings/user_dashboard.php
Auto-merging core/user_settings/app_menu.php
CONFLICT (add/add): Merge conflict in core/user_settings/app_menu.php
Auto-merging core/user_settings/app_languages.php
CONFLICT (add/add): Merge conflict in core/user_settings/app_languages.php
Auto-merging core/user_settings/app_config.php
CONFLICT (add/add): Merge conflict in core/user_settings/app_config.php
Auto-merging core/upgrade/index.php
CONFLICT (add/add): Merge conflict in core/upgrade/index.php
Auto-merging core/upgrade/app_menu.php
CONFLICT (add/add): Merge conflict in core/upgrade/app_menu.php
Auto-merging core/upgrade/app_languages.php
CONFLICT (add/add): Merge conflict in core/upgrade/app_languages.php
Auto-merging core/upgrade/app_defaults.php
CONFLICT (content): Merge conflict in core/upgrade/app_defaults.php
Auto-merging core/upgrade/app_config.php
CONFLICT (content): Merge conflict in core/upgrade/app_config.php
Auto-merging core/software/resources/classes/software.php
CONFLICT (add/add): Merge conflict in core/software/resources/classes/software.php
Auto-merging core/software/app_defaults.php
CONFLICT (add/add): Merge conflict in core/software/app_defaults.php
Auto-merging core/software/app_config.php
CONFLICT (add/add): Merge conflict in core/software/app_config.php
Auto-merging core/permissions/app_config.php
CONFLICT (add/add): Merge conflict in core/permissions/app_config.php
Auto-merging core/notifications/app_menu.php
CONFLICT (add/add): Merge conflict in core/notifications/app_menu.php
Auto-merging core/notifications/app_languages.php
CONFLICT (add/add): Merge conflict in core/notifications/app_languages.php
Auto-merging core/notifications/app_config.php
CONFLICT (add/add): Merge conflict in core/notifications/app_config.php
Auto-merging core/menu/menu_item_list.php
CONFLICT (content): Merge conflict in core/menu/menu_item_list.php
Auto-merging core/menu/menu_edit.php
CONFLICT (content): Merge conflict in core/menu/menu_edit.php
Auto-merging core/menu/menu.php
CONFLICT (content): Merge conflict in core/menu/menu.php
Auto-merging core/menu/app_menu.php
CONFLICT (add/add): Merge conflict in core/menu/app_menu.php
Auto-merging core/menu/app_languages.php
CONFLICT (add/add): Merge conflict in core/menu/app_languages.php
Auto-merging core/menu/app_config.php
CONFLICT (content): Merge conflict in core/menu/app_config.php
Auto-merging core/install/app_languages.php
CONFLICT (add/add): Merge conflict in core/install/app_languages.php
Auto-merging core/install/app_config.php
CONFLICT (add/add): Merge conflict in core/install/app_config.php
Auto-merging core/groups/resources/classes/groups.php
CONFLICT (add/add): Merge conflict in core/groups/resources/classes/groups.php
Auto-merging core/groups/groups.php
CONFLICT (add/add): Merge conflict in core/groups/groups.php
Auto-merging core/groups/groupmemberdelete.php
CONFLICT (add/add): Merge conflict in core/groups/groupmemberdelete.php
Auto-merging core/groups/groupmemberadd.php
CONFLICT (add/add): Merge conflict in core/groups/groupmemberadd.php
Auto-merging core/groups/group_permissions.php
CONFLICT (add/add): Merge conflict in core/groups/group_permissions.php
Auto-merging core/groups/group_edit.php
CONFLICT (add/add): Merge conflict in core/groups/group_edit.php
Auto-merging core/groups/app_menu.php
CONFLICT (add/add): Merge conflict in core/groups/app_menu.php
Auto-merging core/groups/app_languages.php
CONFLICT (add/add): Merge conflict in core/groups/app_languages.php
Auto-merging core/groups/app_config.php
CONFLICT (add/add): Merge conflict in core/groups/app_config.php
Auto-merging core/domains/domains.php
CONFLICT (content): Merge conflict in core/domains/domains.php
Auto-merging core/domains/domain_edit.php
CONFLICT (add/add): Merge conflict in core/domains/domain_edit.php
Auto-merging core/domains/app_menu.php
CONFLICT (add/add): Merge conflict in core/domains/app_menu.php
Auto-merging core/domains/app_languages.php
CONFLICT (add/add): Merge conflict in core/domains/app_languages.php
Auto-merging core/domains/app_config.php
CONFLICT (content): Merge conflict in core/domains/app_config.php
Auto-merging core/domain_settings/domain_settings.php
CONFLICT (add/add): Merge conflict in core/domain_settings/domain_settings.php
Auto-merging core/domain_settings/domain_setting_edit.php
CONFLICT (add/add): Merge conflict in core/domain_settings/domain_setting_edit.php
Auto-merging core/domain_settings/app_menu.php
CONFLICT (add/add): Merge conflict in core/domain_settings/app_menu.php
Auto-merging core/domain_settings/app_languages.php
CONFLICT (add/add): Merge conflict in core/domain_settings/app_languages.php
Auto-merging core/domain_settings/app_config.php
CONFLICT (add/add): Merge conflict in core/domain_settings/app_config.php
Auto-merging core/default_settings/default_settings.php
CONFLICT (content): Merge conflict in core/default_settings/default_settings.php
Auto-merging core/default_settings/default_setting_edit.php
CONFLICT (content): Merge conflict in core/default_settings/default_setting_edit.php
Auto-merging core/default_settings/app_menu.php
CONFLICT (add/add): Merge conflict in core/default_settings/app_menu.php
Auto-merging core/default_settings/app_languages.php
CONFLICT (add/add): Merge conflict in core/default_settings/app_languages.php
Auto-merging core/default_settings/app_defaults.php
CONFLICT (content): Merge conflict in core/default_settings/app_defaults.php
Auto-merging core/default_settings/app_config.php
CONFLICT (content): Merge conflict in core/default_settings/app_config.php
Auto-merging core/databases/databases.php
CONFLICT (content): Merge conflict in core/databases/databases.php
Auto-merging core/databases/database_edit.php
CONFLICT (content): Merge conflict in core/databases/database_edit.php
Auto-merging core/databases/app_menu.php
CONFLICT (add/add): Merge conflict in core/databases/app_menu.php
Auto-merging core/databases/app_languages.php
CONFLICT (add/add): Merge conflict in core/databases/app_languages.php
Auto-merging core/databases/app_config.php
CONFLICT (content): Merge conflict in core/databases/app_config.php
Auto-merging core/authentication/app_config.php
CONFLICT (add/add): Merge conflict in core/authentication/app_config.php
Auto-merging core/apps/app_menu.php
CONFLICT (add/add): Merge conflict in core/apps/app_menu.php
Auto-merging core/apps/app_languages.php
CONFLICT (add/add): Merge conflict in core/apps/app_languages.php
Auto-merging core/apps/app_config.php
CONFLICT (content): Merge conflict in core/apps/app_config.php
Auto-merging app/yealink/app_config.php
CONFLICT (add/add): Merge conflict in app/yealink/app_config.php
Auto-merging app/xml_cdr/xml_cdr_inc.php
CONFLICT (content): Merge conflict in app/xml_cdr/xml_cdr_inc.php
Auto-merging app/xml_cdr/xml_cdr.php
CONFLICT (content): Merge conflict in app/xml_cdr/xml_cdr.php
Auto-merging app/xml_cdr/v_xml_cdr_import.php
CONFLICT (content): Merge conflict in app/xml_cdr/v_xml_cdr_import.php
Auto-merging app/xml_cdr/resources/classes/xml_cdr.php
CONFLICT (add/add): Merge conflict in app/xml_cdr/resources/classes/xml_cdr.php
Auto-merging app/xml_cdr/app_menu.php
CONFLICT (add/add): Merge conflict in app/xml_cdr/app_menu.php
Auto-merging app/xml_cdr/app_languages.php
CONFLICT (content): Merge conflict in app/xml_cdr/app_languages.php
Auto-merging app/xml_cdr/app_config.php
CONFLICT (content): Merge conflict in app/xml_cdr/app_config.php
Auto-merging app/voicemails/voicemails.php
CONFLICT (add/add): Merge conflict in app/voicemails/voicemails.php
Auto-merging app/voicemails/voicemail_messages.php
CONFLICT (add/add): Merge conflict in app/voicemails/voicemail_messages.php
Auto-merging app/voicemails/voicemail_edit.php
CONFLICT (add/add): Merge conflict in app/voicemails/voicemail_edit.php
Auto-merging app/voicemails/resources/classes/voicemail.php
CONFLICT (add/add): Merge conflict in app/voicemails/resources/classes/voicemail.php
Auto-merging app/voicemails/app_menu.php
CONFLICT (add/add): Merge conflict in app/voicemails/app_menu.php
Auto-merging app/voicemails/app_languages.php
CONFLICT (add/add): Merge conflict in app/voicemails/app_languages.php
Auto-merging app/voicemails/app_config.php
CONFLICT (add/add): Merge conflict in app/voicemails/app_config.php
Auto-merging app/voicemail_greetings/voicemail_greetings.php
CONFLICT (content): Merge conflict in app/voicemail_greetings/voicemail_greetings.php
Auto-merging app/voicemail_greetings/voicemail_greeting_edit.php
CONFLICT (content): Merge conflict in app/voicemail_greetings/voicemail_greeting_edit.php
Auto-merging app/voicemail_greetings/resources/classes/voicemail_greetings.php
CONFLICT (add/add): Merge conflict in app/voicemail_greetings/resources/classes/voicemail_greetings.php
Auto-merging app/voicemail_greetings/app_languages.php
CONFLICT (content): Merge conflict in app/voicemail_greetings/app_languages.php
Auto-merging app/voicemail_greetings/app_config.php
CONFLICT (content): Merge conflict in app/voicemail_greetings/app_config.php
Auto-merging app/vars/vars.php
CONFLICT (content): Merge conflict in app/vars/vars.php
Auto-merging app/vars/app_menu.php
CONFLICT (add/add): Merge conflict in app/vars/app_menu.php
Auto-merging app/vars/app_languages.php
CONFLICT (add/add): Merge conflict in app/vars/app_languages.php
Auto-merging app/vars/app_config.php
CONFLICT (content): Merge conflict in app/vars/app_config.php
Auto-merging app/tones/app_languages.php
CONFLICT (add/add): Merge conflict in app/tones/app_languages.php
Auto-merging app/tones/app_config.php
CONFLICT (add/add): Merge conflict in app/tones/app_config.php
Auto-merging app/time_conditions/time_conditions.php
CONFLICT (add/add): Merge conflict in app/time_conditions/time_conditions.php
Auto-merging app/time_conditions/time_condition_edit.php
CONFLICT (add/add): Merge conflict in app/time_conditions/time_condition_edit.php
Auto-merging app/time_conditions/app_menu.php
CONFLICT (add/add): Merge conflict in app/time_conditions/app_menu.php
Auto-merging app/time_conditions/app_languages.php
CONFLICT (content): Merge conflict in app/time_conditions/app_languages.php
Auto-merging app/time_conditions/app_config.php
CONFLICT (content): Merge conflict in app/time_conditions/app_config.php
Auto-merging app/system/app_menu.php
CONFLICT (add/add): Merge conflict in app/system/app_menu.php
Auto-merging app/system/app_languages.php
CONFLICT (content): Merge conflict in app/system/app_languages.php
Auto-merging app/system/app_config.php
CONFLICT (content): Merge conflict in app/system/app_config.php
Auto-merging app/swissvoice/app_config.php
CONFLICT (add/add): Merge conflict in app/swissvoice/app_config.php
Auto-merging app/streams/streams.php
CONFLICT (add/add): Merge conflict in app/streams/streams.php
Auto-merging app/streams/resources/classes/streams.php
CONFLICT (add/add): Merge conflict in app/streams/resources/classes/streams.php
Auto-merging app/streams/app_menu.php
CONFLICT (add/add): Merge conflict in app/streams/app_menu.php
Auto-merging app/streams/app_languages.php
CONFLICT (add/add): Merge conflict in app/streams/app_languages.php
Auto-merging app/streams/app_config.php
CONFLICT (add/add): Merge conflict in app/streams/app_config.php
Auto-merging app/snom/app_config.php
CONFLICT (add/add): Merge conflict in app/snom/app_config.php
Auto-merging app/sip_status/app_menu.php
CONFLICT (add/add): Merge conflict in app/sip_status/app_menu.php
Auto-merging app/sip_status/app_languages.php
CONFLICT (content): Merge conflict in app/sip_status/app_languages.php
Auto-merging app/sip_status/app_config.php
CONFLICT (content): Merge conflict in app/sip_status/app_config.php
Auto-merging app/sip_profiles/sip_profiles.php
CONFLICT (content): Merge conflict in app/sip_profiles/sip_profiles.php
Auto-merging app/sip_profiles/sip_profile_edit.php
CONFLICT (add/add): Merge conflict in app/sip_profiles/sip_profile_edit.php
Auto-merging app/sip_profiles/sip_profile_copy.php
CONFLICT (content): Merge conflict in app/sip_profiles/sip_profile_copy.php
Auto-merging app/sip_profiles/app_menu.php
CONFLICT (add/add): Merge conflict in app/sip_profiles/app_menu.php
Auto-merging app/sip_profiles/app_languages.php
CONFLICT (add/add): Merge conflict in app/sip_profiles/app_languages.php
Auto-merging app/sip_profiles/app_config.php
CONFLICT (content): Merge conflict in app/sip_profiles/app_config.php
Auto-merging app/settings/app_menu.php
CONFLICT (add/add): Merge conflict in app/settings/app_menu.php
Auto-merging app/settings/app_languages.php
CONFLICT (content): Merge conflict in app/settings/app_languages.php
Auto-merging app/settings/app_config.php
CONFLICT (content): Merge conflict in app/settings/app_config.php
Auto-merging app/scripts/resources/scripts/fax_retry.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/fax_retry.lua
Auto-merging app/scripts/resources/scripts/disa.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/disa.lua
Auto-merging app/scripts/resources/scripts/call_flow.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/call_flow.lua
Auto-merging app/scripts/resources/scripts/app/xml_handler/resources/scripts/directory/directory.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/xml_handler/resources/scripts/directory/directory.lua
Auto-merging app/scripts/resources/scripts/app/xml_handler/resources/scripts/configuration/ivr.conf.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/xml_handler/resources/scripts/configuration/ivr.conf.lua
Auto-merging app/scripts/resources/scripts/app/xml_handler/resources/scripts/configuration/callcenter.conf.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/xml_handler/resources/scripts/configuration/callcenter.conf.lua
Auto-merging app/scripts/resources/scripts/app/voicemail/resources/functions/record_message.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/voicemail/resources/functions/record_message.lua
Auto-merging app/scripts/resources/scripts/app/voicemail/resources/functions/macro.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/voicemail/resources/functions/macro.lua
Auto-merging app/scripts/resources/scripts/app/voicemail/index.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/voicemail/index.lua
Auto-merging app/scripts/resources/scripts/app/ring_groups/index.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/ring_groups/index.lua
Auto-merging app/scripts/resources/scripts/app/is_local/index.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/is_local/index.lua
Auto-merging app/scripts/resources/scripts/app/follow_me/index.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/follow_me/index.lua
Auto-merging app/scripts/resources/scripts/app/conference_center/index.lua
CONFLICT (add/add): Merge conflict in app/scripts/resources/scripts/app/conference_center/index.lua
Auto-merging app/ring_groups/ring_groups.php
CONFLICT (content): Merge conflict in app/ring_groups/ring_groups.php
Auto-merging app/ring_groups/ring_group_forward.php
CONFLICT (add/add): Merge conflict in app/ring_groups/ring_group_forward.php
Auto-merging app/ring_groups/ring_group_edit.php
CONFLICT (add/add): Merge conflict in app/ring_groups/ring_group_edit.php
Auto-merging app/ring_groups/app_menu.php
CONFLICT (add/add): Merge conflict in app/ring_groups/app_menu.php
Auto-merging app/ring_groups/app_languages.php
CONFLICT (content): Merge conflict in app/ring_groups/app_languages.php
Auto-merging app/ring_groups/app_config.php
CONFLICT (content): Merge conflict in app/ring_groups/app_config.php
Auto-merging app/registrations/resources/classes/registrations.php
CONFLICT (add/add): Merge conflict in app/registrations/resources/classes/registrations.php
Auto-merging app/registrations/registrations.php
CONFLICT (add/add): Merge conflict in app/registrations/registrations.php
Auto-merging app/registrations/app_menu.php
CONFLICT (add/add): Merge conflict in app/registrations/app_menu.php
Auto-merging app/registrations/app_languages.php
CONFLICT (content): Merge conflict in app/registrations/app_languages.php
Auto-merging app/registrations/app_config.php
CONFLICT (content): Merge conflict in app/registrations/app_config.php
Auto-merging app/recordings/recordings.php
CONFLICT (content): Merge conflict in app/recordings/recordings.php
Auto-merging app/recordings/recording_edit.php
CONFLICT (add/add): Merge conflict in app/recordings/recording_edit.php
Auto-merging app/recordings/app_menu.php
CONFLICT (add/add): Merge conflict in app/recordings/app_menu.php
Auto-merging app/recordings/app_languages.php
CONFLICT (content): Merge conflict in app/recordings/app_languages.php
Auto-merging app/recordings/app_config.php
CONFLICT (content): Merge conflict in app/recordings/app_config.php
Auto-merging app/provision/index.php
CONFLICT (content): Merge conflict in app/provision/index.php
Auto-merging app/provision/app_menu.php
CONFLICT (add/add): Merge conflict in app/provision/app_menu.php
Auto-merging app/provision/app_defaults.php
CONFLICT (content): Merge conflict in app/provision/app_defaults.php
Auto-merging app/provision/app_config.php
CONFLICT (content): Merge conflict in app/provision/app_config.php
Auto-merging app/polycom/app_config.php
CONFLICT (add/add): Merge conflict in app/polycom/app_config.php
Auto-merging app/poly/app_config.php
CONFLICT (add/add): Merge conflict in app/poly/app_config.php
Auto-merging app/pin_numbers/pin_numbers.php
CONFLICT (add/add): Merge conflict in app/pin_numbers/pin_numbers.php
Auto-merging app/pin_numbers/app_menu.php
CONFLICT (add/add): Merge conflict in app/pin_numbers/app_menu.php
Auto-merging app/pin_numbers/app_languages.php
CONFLICT (add/add): Merge conflict in app/pin_numbers/app_languages.php
Auto-merging app/pin_numbers/app_config.php
CONFLICT (add/add): Merge conflict in app/pin_numbers/app_config.php
Auto-merging app/phrases/phrases.php
CONFLICT (add/add): Merge conflict in app/phrases/phrases.php
Auto-merging app/phrases/phrase_edit.php
CONFLICT (add/add): Merge conflict in app/phrases/phrase_edit.php
Auto-merging app/phrases/app_menu.php
CONFLICT (add/add): Merge conflict in app/phrases/app_menu.php
Auto-merging app/phrases/app_languages.php
CONFLICT (add/add): Merge conflict in app/phrases/app_languages.php
Auto-merging app/phrases/app_config.php
CONFLICT (add/add): Merge conflict in app/phrases/app_config.php
Auto-merging app/number_translations/number_translations.php
CONFLICT (add/add): Merge conflict in app/number_translations/number_translations.php
Auto-merging app/number_translations/number_translation_edit.php
CONFLICT (add/add): Merge conflict in app/number_translations/number_translation_edit.php
Auto-merging app/number_translations/app_menu.php
CONFLICT (add/add): Merge conflict in app/number_translations/app_menu.php
Auto-merging app/number_translations/app_languages.php
CONFLICT (add/add): Merge conflict in app/number_translations/app_languages.php
Auto-merging app/number_translations/app_config.php
CONFLICT (add/add): Merge conflict in app/number_translations/app_config.php
Auto-merging app/music_on_hold/resources/classes/switch_music_on_hold.php
CONFLICT (content): Merge conflict in app/music_on_hold/resources/classes/switch_music_on_hold.php
Auto-merging app/music_on_hold/music_on_hold.php
CONFLICT (content): Merge conflict in app/music_on_hold/music_on_hold.php
Auto-merging app/music_on_hold/app_menu.php
CONFLICT (add/add): Merge conflict in app/music_on_hold/app_menu.php
Auto-merging app/music_on_hold/app_languages.php
CONFLICT (add/add): Merge conflict in app/music_on_hold/app_languages.php
Auto-merging app/music_on_hold/app_config.php
CONFLICT (content): Merge conflict in app/music_on_hold/app_config.php
Auto-merging app/modules/modules.php
CONFLICT (content): Merge conflict in app/modules/modules.php
Auto-merging app/modules/app_menu.php
CONFLICT (add/add): Merge conflict in app/modules/app_menu.php
Auto-merging app/modules/app_languages.php
CONFLICT (add/add): Merge conflict in app/modules/app_languages.php
Auto-merging app/modules/app_config.php
CONFLICT (content): Merge conflict in app/modules/app_config.php
Auto-merging app/messages/messages_log.php
CONFLICT (add/add): Merge conflict in app/messages/messages_log.php
Auto-merging app/messages/message_edit.php
CONFLICT (add/add): Merge conflict in app/messages/message_edit.php
Auto-merging app/messages/app_menu.php
CONFLICT (add/add): Merge conflict in app/messages/app_menu.php
Auto-merging app/messages/app_languages.php
CONFLICT (add/add): Merge conflict in app/messages/app_languages.php
Auto-merging app/messages/app_config.php
CONFLICT (add/add): Merge conflict in app/messages/app_config.php
Auto-merging app/meetings/app_menu.php
CONFLICT (add/add): Merge conflict in app/meetings/app_menu.php
Auto-merging app/meetings/app_config.php
CONFLICT (content): Merge conflict in app/meetings/app_config.php
Auto-merging app/log_viewer/app_menu.php
CONFLICT (add/add): Merge conflict in app/log_viewer/app_menu.php
Auto-merging app/log_viewer/app_languages.php
CONFLICT (add/add): Merge conflict in app/log_viewer/app_languages.php
Auto-merging app/log_viewer/app_config.php
CONFLICT (content): Merge conflict in app/log_viewer/app_config.php
Auto-merging app/ivr_menus/ivr_menus.php
CONFLICT (add/add): Merge conflict in app/ivr_menus/ivr_menus.php
Auto-merging app/ivr_menus/ivr_menu_edit.php
CONFLICT (add/add): Merge conflict in app/ivr_menus/ivr_menu_edit.php
Auto-merging app/ivr_menus/app_menu.php
CONFLICT (add/add): Merge conflict in app/ivr_menus/app_menu.php
Auto-merging app/ivr_menus/app_languages.php
CONFLICT (add/add): Merge conflict in app/ivr_menus/app_languages.php
Auto-merging app/ivr_menus/app_config.php
CONFLICT (add/add): Merge conflict in app/ivr_menus/app_config.php
Auto-merging app/htek/app_config.php
CONFLICT (add/add): Merge conflict in app/htek/app_config.php
Auto-merging app/gswave/app_menu.php
CONFLICT (add/add): Merge conflict in app/gswave/app_menu.php
Auto-merging app/gswave/app_languages.php
CONFLICT (add/add): Merge conflict in app/gswave/app_languages.php
Auto-merging app/gswave/app_config.php
CONFLICT (add/add): Merge conflict in app/gswave/app_config.php
Auto-merging app/grandstream/app_config.php
CONFLICT (add/add): Merge conflict in app/grandstream/app_config.php
Auto-merging app/gateways/gateways.php
CONFLICT (content): Merge conflict in app/gateways/gateways.php
Auto-merging app/gateways/gateway_edit.php
CONFLICT (content): Merge conflict in app/gateways/gateway_edit.php
Auto-merging app/gateways/app_menu.php
CONFLICT (add/add): Merge conflict in app/gateways/app_menu.php
Auto-merging app/gateways/app_languages.php
CONFLICT (add/add): Merge conflict in app/gateways/app_languages.php
Auto-merging app/gateways/app_config.php
CONFLICT (content): Merge conflict in app/gateways/app_config.php
Auto-merging app/follow_me/app_menu.php
CONFLICT (add/add): Merge conflict in app/follow_me/app_menu.php
Auto-merging app/follow_me/app_config.php
CONFLICT (content): Merge conflict in app/follow_me/app_config.php
Auto-merging app/fifo_list/app_menu.php
CONFLICT (add/add): Merge conflict in app/fifo_list/app_menu.php
Auto-merging app/fifo_list/app_languages.php
CONFLICT (add/add): Merge conflict in app/fifo_list/app_languages.php
Auto-merging app/fifo_list/app_config.php
CONFLICT (content): Merge conflict in app/fifo_list/app_config.php
Auto-merging app/fifo/app_menu.php
CONFLICT (add/add): Merge conflict in app/fifo/app_menu.php
Auto-merging app/fifo/app_languages.php
CONFLICT (add/add): Merge conflict in app/fifo/app_languages.php
Auto-merging app/fifo/app_config.php
CONFLICT (content): Merge conflict in app/fifo/app_config.php
Auto-merging app/fax/fax_send.php
CONFLICT (add/add): Merge conflict in app/fax/fax_send.php
Auto-merging app/fax/fax_logs.php
CONFLICT (add/add): Merge conflict in app/fax/fax_logs.php
Auto-merging app/fax/fax_log_view.php
CONFLICT (add/add): Merge conflict in app/fax/fax_log_view.php
Auto-merging app/fax/fax_files.php
CONFLICT (add/add): Merge conflict in app/fax/fax_files.php
Auto-merging app/fax/fax_edit.php
CONFLICT (content): Merge conflict in app/fax/fax_edit.php
Auto-merging app/fax/fax_active.php
CONFLICT (add/add): Merge conflict in app/fax/fax_active.php
Auto-merging app/fax/fax.php
CONFLICT (content): Merge conflict in app/fax/fax.php
Auto-merging app/fax/app_menu.php
CONFLICT (add/add): Merge conflict in app/fax/app_menu.php
Auto-merging app/fax/app_languages.php
CONFLICT (content): Merge conflict in app/fax/app_languages.php
Auto-merging app/fax/app_config.php
CONFLICT (content): Merge conflict in app/fax/app_config.php
Auto-merging app/fanvil/app_config.php
CONFLICT (add/add): Merge conflict in app/fanvil/app_config.php
Auto-merging app/extensions/extensions.php
CONFLICT (content): Merge conflict in app/extensions/extensions.php
Auto-merging app/extensions/extension_edit.php
CONFLICT (content): Merge conflict in app/extensions/extension_edit.php
Auto-merging app/extensions/extension_copy.php
CONFLICT (content): Merge conflict in app/extensions/extension_copy.php
Auto-merging app/extensions/app_menu.php
CONFLICT (add/add): Merge conflict in app/extensions/app_menu.php
Auto-merging app/extensions/app_languages.php
CONFLICT (add/add): Merge conflict in app/extensions/app_languages.php
Auto-merging app/extensions/app_config.php
CONFLICT (content): Merge conflict in app/extensions/app_config.php
Auto-merging app/errors/app_menu.php
CONFLICT (add/add): Merge conflict in app/errors/app_menu.php
Auto-merging app/errors/app_languages.php
CONFLICT (add/add): Merge conflict in app/errors/app_languages.php
Auto-merging app/errors/app_config.php
CONFLICT (add/add): Merge conflict in app/errors/app_config.php
Auto-merging app/email_templates/email_templates.php
CONFLICT (add/add): Merge conflict in app/email_templates/email_templates.php
Auto-merging app/email_templates/app_menu.php
CONFLICT (add/add): Merge conflict in app/email_templates/app_menu.php
Auto-merging app/email_templates/app_languages.php
CONFLICT (add/add): Merge conflict in app/email_templates/app_languages.php
Auto-merging app/email_templates/app_defaults.php
CONFLICT (add/add): Merge conflict in app/email_templates/app_defaults.php
Auto-merging app/email_templates/app_config.php
CONFLICT (add/add): Merge conflict in app/email_templates/app_config.php
Auto-merging app/email_logs/email_logs.php
CONFLICT (add/add): Merge conflict in app/email_logs/email_logs.php
Auto-merging app/email_logs/app_menu.php
CONFLICT (add/add): Merge conflict in app/email_logs/app_menu.php
Auto-merging app/email_logs/app_languages.php
CONFLICT (add/add): Merge conflict in app/email_logs/app_languages.php
Auto-merging app/email_logs/app_config.php
CONFLICT (add/add): Merge conflict in app/email_logs/app_config.php
Auto-merging app/dialplans/resources/switch/conf/dialplan/900_voicemail.xml
CONFLICT (add/add): Merge conflict in app/dialplans/resources/switch/conf/dialplan/900_voicemail.xml
Auto-merging app/dialplans/resources/switch/conf/dialplan/507_call_forward_not_registered.xml
CONFLICT (add/add): Merge conflict in app/dialplans/resources/switch/conf/dialplan/507_call_forward_not_registered.xml
Auto-merging app/dialplans/resources/switch/conf/dialplan/505_call-forward-all.xml
CONFLICT (add/add): Merge conflict in app/dialplans/resources/switch/conf/dialplan/505_call-forward-all.xml
Auto-merging app/dialplans/resources/switch/conf/dialplan/300_dx.xml
CONFLICT (add/add): Merge conflict in app/dialplans/resources/switch/conf/dialplan/300_dx.xml
Auto-merging app/dialplans/dialplans.php
CONFLICT (add/add): Merge conflict in app/dialplans/dialplans.php
Auto-merging app/dialplans/dialplan_edit.php
CONFLICT (add/add): Merge conflict in app/dialplans/dialplan_edit.php
Auto-merging app/dialplans/app_menu.php
CONFLICT (add/add): Merge conflict in app/dialplans/app_menu.php
Auto-merging app/dialplans/app_languages.php
CONFLICT (add/add): Merge conflict in app/dialplans/app_languages.php
Auto-merging app/dialplans/app_config.php
CONFLICT (add/add): Merge conflict in app/dialplans/app_config.php
Auto-merging app/dialplan_outbound/dialplan_outbound_add.php
CONFLICT (content): Merge conflict in app/dialplan_outbound/dialplan_outbound_add.php
Auto-merging app/dialplan_outbound/app_menu.php
CONFLICT (add/add): Merge conflict in app/dialplan_outbound/app_menu.php
Auto-merging app/dialplan_outbound/app_languages.php
CONFLICT (add/add): Merge conflict in app/dialplan_outbound/app_languages.php
Auto-merging app/dialplan_outbound/app_config.php
CONFLICT (content): Merge conflict in app/dialplan_outbound/app_config.php
Auto-merging app/dialplan_inbound/app_menu.php
CONFLICT (add/add): Merge conflict in app/dialplan_inbound/app_menu.php
Auto-merging app/dialplan_inbound/app_languages.php
CONFLICT (add/add): Merge conflict in app/dialplan_inbound/app_languages.php
Auto-merging app/dialplan_inbound/app_config.php
CONFLICT (content): Merge conflict in app/dialplan_inbound/app_config.php
Auto-merging app/devices/devices.php
CONFLICT (add/add): Merge conflict in app/devices/devices.php
Auto-merging app/devices/device_vendors.php
CONFLICT (add/add): Merge conflict in app/devices/device_vendors.php
Auto-merging app/devices/device_vendor_functions.php
CONFLICT (add/add): Merge conflict in app/devices/device_vendor_functions.php
Auto-merging app/devices/device_profiles.php
CONFLICT (add/add): Merge conflict in app/devices/device_profiles.php
Auto-merging app/devices/device_profile_edit.php
CONFLICT (add/add): Merge conflict in app/devices/device_profile_edit.php
Auto-merging app/devices/device_profile_copy.php
CONFLICT (add/add): Merge conflict in app/devices/device_profile_copy.php
Auto-merging app/devices/device_edit.php
CONFLICT (add/add): Merge conflict in app/devices/device_edit.php
Auto-merging app/devices/device_dashboard.php
CONFLICT (add/add): Merge conflict in app/devices/device_dashboard.php
Auto-merging app/devices/app_menu.php
CONFLICT (add/add): Merge conflict in app/devices/app_menu.php
Auto-merging app/devices/app_languages.php
CONFLICT (add/add): Merge conflict in app/devices/app_languages.php
Auto-merging app/devices/app_config.php
CONFLICT (add/add): Merge conflict in app/devices/app_config.php
Auto-merging app/destinations/resources/classes/destinations.php
CONFLICT (add/add): Merge conflict in app/destinations/resources/classes/destinations.php
Auto-merging app/destinations/destinations.php
CONFLICT (content): Merge conflict in app/destinations/destinations.php
Auto-merging app/destinations/destination_imports.php
CONFLICT (add/add): Merge conflict in app/destinations/destination_imports.php
Auto-merging app/destinations/destination_edit.php
CONFLICT (add/add): Merge conflict in app/destinations/destination_edit.php
Auto-merging app/destinations/app_menu.php
CONFLICT (add/add): Merge conflict in app/destinations/app_menu.php
Auto-merging app/destinations/app_languages.php
CONFLICT (add/add): Merge conflict in app/destinations/app_languages.php
Auto-merging app/destinations/app_config.php
CONFLICT (content): Merge conflict in app/destinations/app_config.php
Auto-merging app/database_transactions/app_menu.php
CONFLICT (add/add): Merge conflict in app/database_transactions/app_menu.php
Auto-merging app/database_transactions/app_languages.php
CONFLICT (add/add): Merge conflict in app/database_transactions/app_languages.php
Auto-merging app/database_transactions/app_config.php
CONFLICT (add/add): Merge conflict in app/database_transactions/app_config.php
Auto-merging app/contacts/resources/images/icon_gmaps.png
CONFLICT (add/add): Merge conflict in app/contacts/resources/images/icon_gmaps.png
Auto-merging app/contacts/contacts.php
CONFLICT (content): Merge conflict in app/contacts/contacts.php
Auto-merging app/contacts/contact_urls.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_urls.php
Auto-merging app/contacts/contact_times.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_times.php
Auto-merging app/contacts/contact_settings.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_settings.php
Auto-merging app/contacts/contact_relations.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_relations.php
Auto-merging app/contacts/contact_phone_edit.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_phone_edit.php
Auto-merging app/contacts/contact_notes.php
CONFLICT (content): Merge conflict in app/contacts/contact_notes.php
Auto-merging app/contacts/contact_import_google.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_import_google.php
Auto-merging app/contacts/contact_emails.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_emails.php
Auto-merging app/contacts/contact_edit.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_edit.php
Auto-merging app/contacts/contact_attachments.php
CONFLICT (add/add): Merge conflict in app/contacts/contact_attachments.php
Auto-merging app/contacts/contact_addresses.php
CONFLICT (content): Merge conflict in app/contacts/contact_addresses.php
Auto-merging app/contacts/app_menu.php
CONFLICT (add/add): Merge conflict in app/contacts/app_menu.php
Auto-merging app/contacts/app_languages.php
CONFLICT (add/add): Merge conflict in app/contacts/app_languages.php
Auto-merging app/contacts/app_config.php
CONFLICT (content): Merge conflict in app/contacts/app_config.php
Auto-merging app/conferences_active/conference_interactive_inc.php
CONFLICT (content): Merge conflict in app/conferences_active/conference_interactive_inc.php
Auto-merging app/conferences_active/conference_exec.php
CONFLICT (content): Merge conflict in app/conferences_active/conference_exec.php
Auto-merging app/conferences_active/app_menu.php
CONFLICT (add/add): Merge conflict in app/conferences_active/app_menu.php
Auto-merging app/conferences_active/app_languages.php
CONFLICT (content): Merge conflict in app/conferences_active/app_languages.php
Auto-merging app/conferences_active/app_config.php
CONFLICT (content): Merge conflict in app/conferences_active/app_config.php
Auto-merging app/conferences/conferences.php
CONFLICT (content): Merge conflict in app/conferences/conferences.php
Auto-merging app/conferences/conference_edit.php
CONFLICT (content): Merge conflict in app/conferences/conference_edit.php
Auto-merging app/conferences/app_menu.php
CONFLICT (add/add): Merge conflict in app/conferences/app_menu.php
Auto-merging app/conferences/app_languages.php
CONFLICT (content): Merge conflict in app/conferences/app_languages.php
Auto-merging app/conferences/app_config.php
CONFLICT (content): Merge conflict in app/conferences/app_config.php
Auto-merging app/conference_profiles/conference_profiles.php
CONFLICT (add/add): Merge conflict in app/conference_profiles/conference_profiles.php
Auto-merging app/conference_profiles/conference_profile_params.php
CONFLICT (add/add): Merge conflict in app/conference_profiles/conference_profile_params.php
Auto-merging app/conference_profiles/app_menu.php
CONFLICT (add/add): Merge conflict in app/conference_profiles/app_menu.php
Auto-merging app/conference_profiles/app_languages.php
CONFLICT (add/add): Merge conflict in app/conference_profiles/app_languages.php
Auto-merging app/conference_profiles/app_config.php
CONFLICT (add/add): Merge conflict in app/conference_profiles/app_config.php
Auto-merging app/conference_controls/conference_controls.php
CONFLICT (add/add): Merge conflict in app/conference_controls/conference_controls.php
Auto-merging app/conference_controls/conference_control_details.php
CONFLICT (add/add): Merge conflict in app/conference_controls/conference_control_details.php
Auto-merging app/conference_controls/app_menu.php
CONFLICT (add/add): Merge conflict in app/conference_controls/app_menu.php
Auto-merging app/conference_controls/app_languages.php
CONFLICT (add/add): Merge conflict in app/conference_controls/app_languages.php
Auto-merging app/conference_controls/app_config.php
CONFLICT (add/add): Merge conflict in app/conference_controls/app_config.php
Auto-merging app/conference_centers/resources/classes/conference_centers.php
CONFLICT (add/add): Merge conflict in app/conference_centers/resources/classes/conference_centers.php
Auto-merging app/conference_centers/download.php
CONFLICT (add/add): Merge conflict in app/conference_centers/download.php
Auto-merging app/conference_centers/conference_sessions.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_sessions.php
Auto-merging app/conference_centers/conference_session_details.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_session_details.php
Auto-merging app/conference_centers/conference_rooms.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_rooms.php
Auto-merging app/conference_centers/conference_room_edit.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_room_edit.php
Auto-merging app/conference_centers/conference_centers.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_centers.php
Auto-merging app/conference_centers/conference_center_edit.php
CONFLICT (content): Merge conflict in app/conference_centers/conference_center_edit.php
Auto-merging app/conference_centers/app_menu.php
CONFLICT (add/add): Merge conflict in app/conference_centers/app_menu.php
Auto-merging app/conference_centers/app_languages.php
CONFLICT (content): Merge conflict in app/conference_centers/app_languages.php
Auto-merging app/conference_centers/app_config.php
CONFLICT (content): Merge conflict in app/conference_centers/app_config.php
Auto-merging app/click_to_call/app_menu.php
CONFLICT (add/add): Merge conflict in app/click_to_call/app_menu.php
Auto-merging app/click_to_call/app_languages.php
CONFLICT (add/add): Merge conflict in app/click_to_call/app_languages.php
Auto-merging app/click_to_call/app_config.php
CONFLICT (content): Merge conflict in app/click_to_call/app_config.php
Auto-merging app/calls_active/calls_active_inc.php
CONFLICT (content): Merge conflict in app/calls_active/calls_active_inc.php
Auto-merging app/calls_active/app_menu.php
CONFLICT (add/add): Merge conflict in app/calls_active/app_menu.php
Auto-merging app/calls_active/app_languages.php
CONFLICT (content): Merge conflict in app/calls_active/app_languages.php
Auto-merging app/calls_active/app_config.php
CONFLICT (content): Merge conflict in app/calls_active/app_config.php
Auto-merging app/calls/calls.php
CONFLICT (content): Merge conflict in app/calls/calls.php
Auto-merging app/calls/call_edit.php
CONFLICT (content): Merge conflict in app/calls/call_edit.php
Auto-merging app/calls/app_menu.php
CONFLICT (add/add): Merge conflict in app/calls/app_menu.php
Auto-merging app/calls/app_languages.php
CONFLICT (content): Merge conflict in app/calls/app_languages.php
Auto-merging app/calls/app_config.php
CONFLICT (content): Merge conflict in app/calls/app_config.php
Auto-merging app/call_recordings/resources/classes/call_recordings.php
CONFLICT (add/add): Merge conflict in app/call_recordings/resources/classes/call_recordings.php
Auto-merging app/call_recordings/call_recordings.php
CONFLICT (add/add): Merge conflict in app/call_recordings/call_recordings.php
Auto-merging app/call_recordings/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_recordings/app_menu.php
Auto-merging app/call_recordings/app_languages.php
CONFLICT (add/add): Merge conflict in app/call_recordings/app_languages.php
Auto-merging app/call_recordings/app_config.php
CONFLICT (add/add): Merge conflict in app/call_recordings/app_config.php
Auto-merging app/call_flows/resources/classes/call_flows.php
CONFLICT (add/add): Merge conflict in app/call_flows/resources/classes/call_flows.php
Auto-merging app/call_flows/call_flows.php
CONFLICT (content): Merge conflict in app/call_flows/call_flows.php
Auto-merging app/call_flows/call_flow_edit.php
CONFLICT (content): Merge conflict in app/call_flows/call_flow_edit.php
Auto-merging app/call_flows/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_flows/app_menu.php
Auto-merging app/call_flows/app_languages.php
CONFLICT (add/add): Merge conflict in app/call_flows/app_languages.php
Auto-merging app/call_flows/app_config.php
CONFLICT (content): Merge conflict in app/call_flows/app_config.php
Auto-merging app/call_centers/call_center_queues.php
CONFLICT (add/add): Merge conflict in app/call_centers/call_center_queues.php
Auto-merging app/call_centers/call_center_queue_edit.php
CONFLICT (add/add): Merge conflict in app/call_centers/call_center_queue_edit.php
Auto-merging app/call_centers/call_center_agents.php
CONFLICT (add/add): Merge conflict in app/call_centers/call_center_agents.php
Auto-merging app/call_centers/call_center_agent_status.php
CONFLICT (add/add): Merge conflict in app/call_centers/call_center_agent_status.php
Auto-merging app/call_centers/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_centers/app_menu.php
Auto-merging app/call_centers/app_languages.php
CONFLICT (add/add): Merge conflict in app/call_centers/app_languages.php
Auto-merging app/call_centers/app_config.php
CONFLICT (add/add): Merge conflict in app/call_centers/app_config.php
Auto-merging app/call_center_active/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_center_active/app_menu.php
Auto-merging app/call_center_active/app_languages.php
CONFLICT (add/add): Merge conflict in app/call_center_active/app_languages.php
Auto-merging app/call_center_active/app_config.php
CONFLICT (content): Merge conflict in app/call_center_active/app_config.php
Auto-merging app/call_broadcast/call_broadcast_send.php
CONFLICT (content): Merge conflict in app/call_broadcast/call_broadcast_send.php
Auto-merging app/call_broadcast/call_broadcast_edit.php
CONFLICT (content): Merge conflict in app/call_broadcast/call_broadcast_edit.php
Auto-merging app/call_broadcast/call_broadcast.php
CONFLICT (content): Merge conflict in app/call_broadcast/call_broadcast.php
Auto-merging app/call_broadcast/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_broadcast/app_menu.php
Auto-merging app/call_broadcast/app_languages.php
CONFLICT (content): Merge conflict in app/call_broadcast/app_languages.php
Auto-merging app/call_broadcast/app_config.php
CONFLICT (content): Merge conflict in app/call_broadcast/app_config.php
Auto-merging app/call_block/call_block_edit.php
CONFLICT (add/add): Merge conflict in app/call_block/call_block_edit.php
Auto-merging app/call_block/call_block.php
CONFLICT (add/add): Merge conflict in app/call_block/call_block.php
Auto-merging app/call_block/app_menu.php
CONFLICT (add/add): Merge conflict in app/call_block/app_menu.php
Auto-merging app/call_block/app_languages.php
CONFLICT (add/add): Merge conflict in app/call_block/app_languages.php
Auto-merging app/call_block/app_config.php
CONFLICT (add/add): Merge conflict in app/call_block/app_config.php
Auto-merging app/bridges/bridges.php
CONFLICT (add/add): Merge conflict in app/bridges/bridges.php
Auto-merging app/bridges/bridge_edit.php
CONFLICT (add/add): Merge conflict in app/bridges/bridge_edit.php
Auto-merging app/bridges/app_menu.php
CONFLICT (add/add): Merge conflict in app/bridges/app_menu.php
Auto-merging app/bridges/app_languages.php
CONFLICT (add/add): Merge conflict in app/bridges/app_languages.php
Auto-merging app/bridges/app_config.php
CONFLICT (add/add): Merge conflict in app/bridges/app_config.php
Auto-merging app/basic_operator_panel/app_menu.php
CONFLICT (add/add): Merge conflict in app/basic_operator_panel/app_menu.php
Auto-merging app/basic_operator_panel/app_languages.php
CONFLICT (add/add): Merge conflict in app/basic_operator_panel/app_languages.php
Auto-merging app/basic_operator_panel/app_config.php
CONFLICT (add/add): Merge conflict in app/basic_operator_panel/app_config.php
Auto-merging app/access_controls/app_menu.php
CONFLICT (add/add): Merge conflict in app/access_controls/app_menu.php
Auto-merging app/access_controls/app_languages.php
CONFLICT (add/add): Merge conflict in app/access_controls/app_languages.php
Auto-merging app/access_controls/app_config.php
CONFLICT (add/add): Merge conflict in app/access_controls/app_config.php
Auto-merging app/access_controls/access_controls.php
CONFLICT (add/add): Merge conflict in app/access_controls/access_controls.php
Auto-merging app/access_controls/access_control_nodes.php
CONFLICT (add/add): Merge conflict in app/access_controls/access_control_nodes.php
Auto-merging app/access_controls/access_control_edit.php
CONFLICT (add/add): Merge conflict in app/access_controls/access_control_edit.php
Auto-merging app/aastra/app_config.php
CONFLICT (add/add): Merge conflict in app/aastra/app_config.php
warning: inexact rename detection was skipped due to too many files.
warning: you may want to set your merge.renamelimit variable to at least 4359 and retry the command.
Automatic merge failed; fix conflicts and then commit the result.
Result of Schema and Data Types checks:
SQL Changes:
ALTER TABLE v_call_broadcasts ADD broadcast_start_time numeric;
ALTER TABLE v_call_flows ADD call_flow_enabled text;
ALTER TABLE v_conference_rooms ADD moderator_endconf text;
ALTER TABLE v_conference_rooms ADD announce_name text;
ALTER TABLE v_conference_rooms ADD announce_count text;
ALTER TABLE v_conference_rooms ADD announce_recording text;
ALTER TABLE v_destinations ADD destination_condition_field text;
ALTER TABLE v_extensions ALTER COLUMN nibble_account TYPE text;
ALTER TABLE v_ivr_menus ADD ivr_menu_parent_uuid uuid;
ALTER TABLE v_ring_groups ADD ring_group_call_forward_enabled text;
ALTER TABLE v_countries RENAME COLUMN calling_code to country_code;
ALTER TABLE v_users ALTER COLUMN api_key TYPE text;
markjcrane
453
162
The fix for this was added as a news item on 7th March 2020.
566
There has also been a sticky post explaining this in the FusionPBX News section since May29th
