SOLVED Setting up Twilio on FusionPBX
phonesimon
87
15
You are obfuscating your logs too much. Makes it hard to see what's going on. Leave the IP addresses in.
You are certainly reaching twilio, because you are getting an initial response from them:
recv 379 bytes from udp/[54.172.60.1]:5060 at 16:05:58.590510:
SIP/2.0 100 Giving a try
Via: SIP/2.0/UDP 100.100.100.100:5080;received=100.100.100.100;rport=5080;branch=z9hG4bK2Q5c9pycaSpmS
From: "asdf" <sip:someguy@gmail.com@vursify.pstn.twilio.com>;tag=mDy3SpvNKrvyD
To: <sip:1234567891@vursify.pstn.twilio.com>
Call-ID: 95ca3ee0-a30d-1236-eab1-56000168b138
CSeq: 120228914 INVITE
Server: Twilio Gateway
Content-Length: 0
The reason I'm asking about your IP is maybe you are sending them a contact header that doesn't get back to your PBX. The Via header I just quoted doesn't tell me whether you are obfuscating a NAT address or a public address. I assume it's public since Twilio puts it in the received= tag but who knows since you changed it all around... Last thought, do you have port 5080 open?
Reactions: DigitalDaz
i3ioi-iazard
52
The Address was indeed a public IP and port 5080 is open.
Ask Twilio, the problem looks to be ate their end as you are getting a timeout from them.
i3ioi-iazard
52
Twilio is saying there's nothing for them to look at since SIP signalling isnt making it up to them. They want me to send Wireshark info for them to look further into it.
Anyone know of a working SIP trunk provider similar to Twilio with similar pricing? I am only using Twilio as I was told its one of the cheapest for rates.
Thats crap:
Content-Length: 0
That comes from twilio gateway
Reactions: phonesimon
As does this:
recv 424 bytes from udp/[54.172.60.1]:5060 at 16:06:06.891917:
SIP/2.0 408 Request Timeout
To: <sip:1234567891@vursify.pstn.twilio.com>;tag=048bc9a6984fdbcd1de39c7c218aea19-3a73
Content-Length: 0
i3ioi-iazard
52
This was resolved. Under Outbound Caller ID Number it needed to have the +1XXXXXXX. Once that was added, it worked well!
The problem I am now having is i can only call the number with 1(123)4567. If I call with +1(123)4567 the call fails the same as if i call (123)4567. The brackets are the area code. Logs indicate the call being rejected.
My dialplan that works by dialing with 1(123)4567 is attached.
i3ioi-iazard
52
Looks like I have sorted everything out. I also gave another SIP trunk provider out and they took all of 2 minutes to configure incoming and outgoing calls.
Thanks everyone for their help!
Andrew Perry
I am trying to do this same setup - would you be able to share your config?
John
97
You make register to NO. Twilio gateway should not be registered. It should be NOREG
agile
27
Hi, I am trying to setup Twilio trunk. Can you please share the screenshots for Gateway setup, outbound and inbound it will be very helpful.
I have registered the Twilio IP address for incoming calls yet it's not accepting the calls. The Gateway is setup as NOREG
