Sip trunk Rotation
103
I have a specific Trunk Group that I like to rotate.
There will be 15 Registrations to 15 different Gateways.
I would like an Outbound Route where Gateway 1 selected when the 1st call is made, Gateway 2 is used when 2nd call is made, Gateway 3 is used when the 3rd call is made and Gateway 4 is used when the 4thbcallbis made and it should continue that way until all 15 Gateways are used.
We need rotate those 15 Gateways in a sequence to balance the load between them.
Could you please help? I've done some testing but not even getting the initial setup right after the trunks are registered.
566
I wouldn't even think of attempting to do that in FusionPBX, you may be able to butcher it around and get it to kind of work but it is far easier to put a kamailio or opensips in between and let one of those two handle it, a job they will handle perfectly.
