Snom Directory
krooney
160
16
Has anyone been able to autoprovision phonebook for snom from contacts?
Any help would be great/
thanks in advance
whut
170
15
@krooney the snom templates will populate the directory from 1) the list of extensions, and 2) the contacts application. Contacts must be managed carefully for them to populate directories for any phone makes and models. I suspect most people will ignore the contacts application because it is not well understood. To populate do this:
- create/edit a contact within your chosen domain
- populate first name and last name fields in the Name section
- set the label as appropriate: home, work...
- set the type to voice
- add a phone number to the number textbox within the Number section
Reactions: krooney
krooney
160
16
Thanks for the update it does populate the contacts from the extension list but not from the contacts list that is my problem right now.
krooney
160
16
