TCP vs UDP and line_sip_transport
kidjake28
97
I noticed that one of the parameters in the default settings 'line_sip_transport' is set for TCP.
I was under the assumption that UDP is a better protocol for voip. Should this not be set to UDP?
Please correct me if I'm wrong.
566
I'm correcting you :)
In almost all cases TCP is better for the SIP transport, particularly when the devices are behind NAT.
Please note, the RTP media stream is still carried over UDP and I think this is where the confusion arises.
