There was an error with ntp and memcache during installation of fusionpbx
Sergey Potap
Dear colleagues!
Yesterday I installed Fusionpbx in a privileged container on Proxmox VE. After installation, there are errors in the guest operating system Debian 10:
root@serg:~# systemctl --failed
UNIT LOAD ACTIVE SUB DESCRIPTION
* logrotate.service loaded failed failed Rotate log files
* memcached.service loaded failed failed memcached daemon
* ntp.service loaded failed failed Network Time Service
* phpsessionclean.service loaded failed failed Clean php session files
Could you please tell me if these errors will affect the further work of the telephone exchange based on Fusionpbx / freeswitch?
And is it possible to somehow remove these errors from the system?
Sergey Potap
SOLVED
He himself asked and he himself answered :)
Decision:
1. Stop the container.
2. In the container settings, in Options> Features, set the Nesting flag.
3. Run the container
4. check the correct operation: systemctl status:
My guest system answers:
0 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
