Upgrade Freeswitch
poddieau
Hi All,
Currently running on the following versions. Should I be upgrading to a newer version of freeswitch and Debian? Many benefits of doing so? Anything I should watch out for?
Also, does anyone have a more straight forward guide to upgrading freeswitch than http://docs.fusionpbx.com/en/latest/advanced/upgrade.html#move-to-the-master-branch?
I find with the guides a lot of directory locations are incorrect, for instance my freeswitch scripts seem to be located at /usr/share/freeswitch/scripts.
System Status
System Information
Version 4.5.2
Git Information Branch: master
Commit: 5dfe0d7a3afc11d932ab14086e594ee6cb82b90d
Status: Your branch is up-to-date with 'origin/master'. +95 days ago
Project Path /var/www/fusionpbx
Switch Version 1.6.20 (64bit)
Operating System Information
Operating System Debian
Version 8.11
Kernel Linux pbx1 3.16.0-5-amd64 #1 SMP Debian 3.16.51-3+deb8u1 (2018-01-08) x86_64 GNU/Linux
Uptime 15:54:14 up 175 days, 1:15, 1 user, load average: 0.24, 0.24, 0.19
Date Wed, 02 Jan 2019 15:54:14 +1000
Kenny Riley
243
I think you are referring to updating FusionPBX. The latest releases are 4.4 stable and 4.5 master. It appears as though you are already running on the latest version of FusionPBX 4.5 master branch. Your last updates were 95 days ago though, so I'd recommend doing an Advanced > Upgrade and upgrading your source code, schema, and app defaults to get the most up to date changes.
Debian 8 is still a secure OS and there really isn't an urgent need to move to Debian 9 that I know of as Debian 8 still has LTS until June of 2020. The guide that you are referring to is from upgrading from an older release to the most current one, which you already have.
poddieau
Hi Kenny, Thanks for your reply.
Should I be looking to upgrade my version of switch as well? Currently I am on 1.6.20 but I note that switch is now past 1.8.
Is there a straightforward process for doing so?
Nick
