SOLVED Use 2 digit in IVR option
mudasar321
81
Hi, I upgraded from version 4.5.8 to 4.5.17, in older version I was able to use 2 digit option it IVR menu. Suppose I set option 20 and destination extension 214, so in IVR during greeting if I press 20 I was routed to extension 214. In newer version it's not working anymore. It works from option [0-9] but does not work 2 digit option. Please advise.
mudasar321
81
Suppose I've set option in IVR 350 and set destination to 350 but call dropped. Here are the logs.
2020-09-24 18:17:09.603975 [NOTICE] switch_channel.c:1114 New Channel sofia/external/Restricted@173.239.37.248 [189d036a-3dcc-4633-9644-7ae979ec3779]
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_NEW (Cur 1 Tot 73)
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:10164 sofia/external/Restricted@173.239.37.248 receiving invite from 173.239.37.248:5060 version: 1.8.7 -8-6047ebddfc 64bit
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:10260 verifying acl "domains" for ip/port 173.239.37.248:0.
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:10289 IP 173.239.37.248 Approved by acl "domains[]". Access Granted.
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:7323 Channel sofia/external/Restricted@173.239.37.248 entering state [received][100]
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:7333 Remote SDP:
v=0
o=root 1989458358 1989458358 IN IP4 173.239.37.248
s=Asterisk PBX 11.6-cert10
c=IN IP4 173.239.37.248
t=0 0
m=audio 17604 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=fmtp:101 0-16
a=ptime:20
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5511 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMU:0:8000:20:64000:1]
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5566 Audio Codec Compare [PCMU:0:8000:20:64000:1] ++++ is saved as a match
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5511 Audio Codec Compare [PCMU:0:8000:20:64000:1]/[PCMA:8:8000:20:64000:1]
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5511 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMU:0:8000:20:64000:1]
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5511 Audio Codec Compare [G729:18:8000:20:8000:1]/[PCMA:8:8000:20:64000:1]
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5427 Set telephone-event payload to 101@8000
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:3781 Set Codec sofia/external/Restricted@173.239.37.248 PCMU/8000 20 ms 160 samples 64000 bits 1 channels
2020-09-24 18:17:09.603975 [DEBUG] switch_core_codec.c:111 sofia/external/Restricted@173.239.37.248 Original read codec set to PCMU:0
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5770 Set telephone-event payload to 101@8000
2020-09-24 18:17:09.603975 [DEBUG] switch_core_media.c:5828 sofia/external/Restricted@173.239.37.248 Set 2833 dtmf send payload to 101 recv payload to 101
2020-09-24 18:17:09.603975 [DEBUG] sofia.c:7748 (sofia/external/Restricted@173.239.37.248) State Change CS_NEW -> CS_INIT
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:603 (sofia/external/Restricted@173.239.37.248) State NEW
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_INIT (Cur 1 Tot 73)
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:627 (sofia/external/Restricted@173.239.37.248) State INIT
2020-09-24 18:17:09.603975 [DEBUG] mod_sofia.c:93 sofia/external/Restricted@173.239.37.248 SOFIA INIT
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:40 sofia/external/Restricted@173.239.37.248 Standard INIT
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:48 (sofia/external/Restricted@173.239.37.248) State Change CS_INIT -> CS_ROUTING
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:627 (sofia/external/Restricted@173.239.37.248) State INIT going to sleep
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_ROUTING (Cur 1 Tot 73)
2020-09-24 18:17:09.603975 [DEBUG] switch_channel.c:2293 (sofia/external/Restricted@173.239.37.248) Callstate Change DOWN -> RINGING
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:643 (sofia/external/Restricted@173.239.37.248) State ROUTING
2020-09-24 18:17:09.603975 [DEBUG] mod_sofia.c:154 sofia/external/Restricted@173.239.37.248 SOFIA ROUTING
2020-09-24 18:17:09.603975 [DEBUG] switch_core_state_machine.c:236 sofia/external/Restricted@173.239.37.248 Standard ROUTING
2020-09-24 18:17:09.603975 [INFO] mod_dialplan_xml.c:637 Processing Anonymous <Restricted>->5162268256 in context public
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [public->caller-details] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [caller-details] () =~ // break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Action export(call_direction=inbound) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 export(call_direction=inbound)
2020-09-24 18:17:09.603975 [DEBUG] switch_channel.c:1306 EXPORT (export_vars) [call_direction]=[inbound]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(caller_destination=${sip_to_user}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(caller_destination=5162268256)
2020-09-24 18:17:09.603975 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [caller_destination]=[5162268256]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(caller_id_name=${caller_id_name}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(caller_id_name=Anonymous)
2020-09-24 18:17:09.603975 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [caller_id_name]=[Anonymous]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(caller_id_number=${caller_id_number})
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [public->6467579144] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [6467579144] destination_number(5162268256) =~ /^(6467579144)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [public->5162268256] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [5162268256] destination_number(5162268256) =~ /^(5162268256)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(domain_uuid=4daea463-a232-4f69-8432-3a2e29cb431c) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(domain_uuid=4daea463-a232-4f69-8432-3a2e29cb431c)
2020-09-24 18:17:09.623966 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [domain_uuid]=[4daea463-a232-4f69-8432-3a2e29cb431c]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(domain_name=ippbx.bpsna.net) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(domain_name=ippbx.bpsna.net)
2020-09-24 18:17:09.623966 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [domain_name]=[ippbx.bpsna.net]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(hangup_after_bridge=true) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(hangup_after_bridge=true)
2020-09-24 18:17:09.623966 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [hangup_after_bridge]=[true]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(continue_on_fail=true) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(continue_on_fail=true)
2020-09-24 18:17:09.623966 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [continue_on_fail]=[true]
Dialplan: sofia/external/Restricted@173.239.37.248 Action transfer(360 XML ippbx.bpsna.net)
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:286 (sofia/external/Restricted@173.239.37.248) State Change CS_ROUTING -> CS_EXECUTE
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:643 (sofia/external/Restricted@173.239.37.248) State ROUTING going to sleep
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_EXECUTE (Cur 1 Tot 73)
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE
2020-09-24 18:17:09.623966 [DEBUG] mod_sofia.c:209 sofia/external/Restricted@173.239.37.248 SOFIA EXECUTE
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:328 sofia/external/Restricted@173.239.37.248 Standard EXECUTE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(caller_id_number=Restricted)
2020-09-24 18:17:09.623966 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [caller_id_number]=[Restricted]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 transfer(360 XML ippbx.bpsna.net)
2020-09-24 18:17:09.623966 [DEBUG] switch_ivr.c:2224 (sofia/external/Restricted@173.239.37.248) State Change CS_EXECUTE -> CS_ROUTING
2020-09-24 18:17:09.623966 [NOTICE] switch_ivr.c:2231 Transfer sofia/external/Restricted@173.239.37.248 to XML[360@ippbx.bpsna.net]
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE going to sleep
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_ROUTING (Cur 1 Tot 73)
2020-09-24 18:17:09.623966 [DEBUG] mod_sofia.c:145 Call appears to be already acknowledged
2020-09-24 18:17:09.623966 [DEBUG] mod_sofia.c:154 sofia/external/Restricted@173.239.37.248 SOFIA ROUTING
2020-09-24 18:17:09.623966 [DEBUG] switch_core_state_machine.c:236 sofia/external/Restricted@173.239.37.248 Standard ROUTING
2020-09-24 18:17:09.623966 [INFO] mod_dialplan_xml.c:637 Processing Anonymous <Restricted>->360 in context ippbx.bpsna.net
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->user_exists] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [user_exists] () =~ // break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(user_exists=${user_exists id ${destination_number} ${domain_name}}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(user_exists=false)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [user_exists]=[false]
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_exists] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->caller-details] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [caller-details] ${caller_destination}(5162268256) =~ /^$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->global-variables] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [global-variables] () =~ // break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(RFC2822_DATE=${strftime(%a, %d %b %Y %T %z)})
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->variables] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [variables] () =~ // break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action export(origination_callee_id_name=${destination_number})
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call-direction] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [call-direction] ${call_direction}(inbound) =~ /^(inbound|outbound|local)$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->is_loopback] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [is_loopback] ${is_follow_me_loopback}() =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call_block] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [call_block] ${call_direction}(inbound) =~ /^inbound$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action lua(app.lua call_block)
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->user_record] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${user_exists}(false) =~ /^true$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${user_record}() =~ /^all$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [user_record] ${call_direction}(inbound) =~ /^inbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^outbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${call_direction}(inbound) =~ /^local$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${user_record}() =~ /^local$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${from_user_exists}() =~ /^true$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${from_user_record}() =~ /^all$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${from_user_record}() =~ /^inbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${from_user_record}() =~ /^outbound$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${from_user_record}() =~ /^local$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_record] ${record_session}() =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->redial] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [redial] destination_number(360) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [redial] () =~ // break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Action hash(insert/${domain_name}-last_dial/${caller_id_number}/${destination_number})
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->speed_dial] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [speed_dial] destination_number(360) =~ /^\*0(.*)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->default_caller_id] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [default_caller_id] ${emergency_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(emergency_caller_id_name=${default_emergency_caller_id_name}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(emergency_caller_id_name=)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [emergency_caller_id_name]=[UNDEF]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(emergency_caller_id_number=${default_emergency_caller_id_number}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(emergency_caller_id_number=)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [emergency_caller_id_number]=[UNDEF]
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [default_caller_id] ${outbound_caller_id_number}() =~ /^$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(outbound_caller_id_name=${default_outbound_caller_id_name}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(outbound_caller_id_name=)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [outbound_caller_id_name]=[UNDEF]
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(outbound_caller_id_number=${default_outbound_caller_id_number}) INLINE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(outbound_caller_id_number=)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [outbound_caller_id_number]=[UNDEF]
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->user_hold_music] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_hold_music] ${hold_music}(local_stream://default) =~ /^$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [user_hold_music] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->Asus.1d10] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [Asus.1d10] ${user_exists}(false) =~ /false/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Asus.1d10] destination_number(360) =~ /^\+?1?(\d{10})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->Test] continue=
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Test] destination_number(360) =~ /^350$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->IVR] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (PASS) [IVR] destination_number(360) =~ /^360$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Action ring_ready()
Dialplan: sofia/external/Restricted@173.239.37.248 Action answer()
Dialplan: sofia/external/Restricted@173.239.37.248 Action sleep(1000)
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(ringback=${us-ring})
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(presence_id=360@ippbx.bpsna.net)
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(default_language=)
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(default_dialect=)
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(default_voice=)
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(transfer_ringback=${us-ring})
Dialplan: sofia/external/Restricted@173.239.37.248 Action set(ivr_menu_uuid=534f42ce-cc21-4534-93d6-23db427e2277)
Dialplan: sofia/external/Restricted@173.239.37.248 Action ivr(534f42ce-cc21-4534-93d6-23db427e2277)
2020-09-24 18:17:09.643994 [DEBUG] switch_core_state_machine.c:286 (sofia/external/Restricted@173.239.37.248) State Change CS_ROUTING -> CS_EXECUTE
2020-09-24 18:17:09.643994 [DEBUG] switch_core_state_machine.c:643 (sofia/external/Restricted@173.239.37.248) State ROUTING going to sleep
2020-09-24 18:17:09.643994 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_EXECUTE (Cur 1 Tot 73)
2020-09-24 18:17:09.643994 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE
2020-09-24 18:17:09.643994 [DEBUG] mod_sofia.c:209 sofia/external/Restricted@173.239.37.248 SOFIA EXECUTE
2020-09-24 18:17:09.643994 [DEBUG] switch_core_state_machine.c:328 sofia/external/Restricted@173.239.37.248 Standard EXECUTE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(RFC2822_DATE=Thu, 24 Sep 2020 18:17:09 -0400)
2020-09-24 18:17:09.643994 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [RFC2822_DATE]=[Thu, 24 Sep 2020 18:17:09 -0400]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 export(origination_callee_id_name=360)
2020-09-24 18:17:09.643994 [DEBUG] switch_channel.c:1306 EXPORT (export_vars) [origination_callee_id_name]=[360]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 lua(app.lua call_block)
2020-09-24 18:17:09.643994 [DEBUG] switch_cpp.cpp:1187 sofia/external/Restricted@173.239.37.248 destroy/unlink session from object
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 hash(insert/ippbx.bpsna.net-last_dial/Restricted/360)
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 ring_ready()
2020-09-24 18:17:09.643994 [NOTICE] mod_sofia.c:2420 Ring-Ready sofia/external/Restricted@173.239.37.248!
2020-09-24 18:17:09.663990 [DEBUG] sofia.c:7323 Channel sofia/external/Restricted@173.239.37.248 entering state [early][180]
2020-09-24 18:17:09.663990 [NOTICE] mod_dptools.c:1093 Ring Ready sofia/external/Restricted@173.239.37.248!
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 answer()
2020-09-24 18:17:09.663990 [DEBUG] switch_core_media.c:8568 AUDIO RTP [sofia/external/Restricted@173.239.37.248] 67.207.180.73 port 32024 -> 173.239.37.248 port 17604 codec: 0 ms: 20
2020-09-24 18:17:09.663990 [DEBUG] switch_rtp.c:4349 Starting timer [soft] 160 bytes per 20ms
2020-09-24 18:17:09.663990 [DEBUG] switch_core_media.c:8875 sofia/external/Restricted@173.239.37.248 Set 2833 dtmf send payload to 101
2020-09-24 18:17:09.663990 [DEBUG] switch_core_media.c:8882 sofia/external/Restricted@173.239.37.248 Set 2833 dtmf receive payload to 101
2020-09-24 18:17:09.663990 [DEBUG] switch_core_media.c:8905 sofia/external/Restricted@173.239.37.248 Set rtp dtmf delay to 40
2020-09-24 18:17:09.663990 [DEBUG] mod_sofia.c:893 Local SDP sofia/external/Restricted@173.239.37.248:
v=0
o=FreeSWITCH 1600953805 1600953806 IN IP4 67.207.180.73
s=FreeSWITCH
c=IN IP4 67.207.180.73
t=0 0
m=audio 32024 RTP/AVP 0 101
a=fmtp:101 0-16
a=ptime:20
a=sendrecv
2020-09-24 18:17:09.663990 [NOTICE] mod_dptools.c:1377 Channel [sofia/external/Restricted@173.239.37.248] has been answered
2020-09-24 18:17:09.663990 [DEBUG] switch_channel.c:3825 (sofia/external/Restricted@173.239.37.248) Callstate Change RINGING -> ACTIVE
2020-09-24 18:17:09.663990 [DEBUG] sofia.c:7323 Channel sofia/external/Restricted@173.239.37.248 entering state [completed][200]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 sleep(1000)
2020-09-24 18:17:09.743969 [DEBUG] sofia.c:7323 Channel sofia/external/Restricted@173.239.37.248 entering state [ready][200]
2020-09-24 18:17:09.803992 [DEBUG] switch_rtp.c:7604 Correct audio ip/port confirmed.
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [hangup_after_bridge]=[true]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(ringback=%(2000,4000,440,480))
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [ringback]=[%(2000,4000,440,480)]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(presence_id=360@ippbx.bpsna.net)
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [presence_id]=[360@ippbx.bpsna.net]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(default_language=)
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [default_language]=[UNDEF]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(default_dialect=)
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [default_dialect]=[UNDEF]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(default_voice=)
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [default_voice]=[UNDEF]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(transfer_ringback=%(2000,4000,440,480))
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [transfer_ringback]=[%(2000,4000,440,480)]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(ivr_menu_uuid=534f42ce-cc21-4534-93d6-23db427e2277)
2020-09-24 18:17:10.683971 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [ivr_menu_uuid]=[534f42ce-cc21-4534-93d6-23db427e2277]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 ivr(534f42ce-cc21-4534-93d6-23db427e2277)
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-exit'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-sub'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-exec-app'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-play-sound'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-back'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:743 switch_ivr_menu_stack_xml_add binding 'menu-top'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:880 building menu '534f42ce-cc21-4534-93d6-23db427e2277'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:964 binding menu action 'menu-exec-app' to '8'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:964 binding menu action 'menu-exec-app' to '350'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:964 binding menu action 'menu-exec-app' to '9'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:964 binding menu action 'menu-exec-app' to '/^(\d{2,11})$/'
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_menu.c:483 Executing IVR menu 534f42ce-cc21-4534-93d6-23db427e2277
2020-09-24 18:17:10.683971 [DEBUG] switch_ivr_play_say.c:1497 Codec Activated L16@8000hz 1 channels 20ms
2020-09-24 18:17:13.723974 [DEBUG] switch_rtp.c:7843 RTP RECV DTMF 3:1120
2020-09-24 18:17:13.723974 [INFO] switch_channel.c:522 RECV DTMF 3:1120
2020-09-24 18:17:13.723974 [DEBUG] switch_ivr_play_say.c:1941 done playing file /var/lib/freeswitch/recordings/ippbx.bpsna.net/BPSNA.wav
2020-09-24 18:17:13.723974 [DEBUG] switch_ivr_menu.c:377 waiting for 4/5 digits t/o 5000
2020-09-24 18:17:14.583979 [DEBUG] switch_rtp.c:7843 RTP RECV DTMF 5:800
2020-09-24 18:17:14.583979 [INFO] switch_channel.c:522 RECV DTMF 5:800
2020-09-24 18:17:15.323970 [DEBUG] switch_rtp.c:7843 RTP RECV DTMF 0:800
2020-09-24 18:17:15.323970 [INFO] switch_channel.c:522 RECV DTMF 0:800
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:424 digits '350'
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'transfer 350 XML ippbx.bpsna.net'
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:581 switch_ivr_menu_execute todo=[2]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 transfer(350 XML ippbx.bpsna.net)
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr.c:2224 (sofia/external/Restricted@173.239.37.248) State Change CS_EXECUTE -> CS_ROUTING
2020-09-24 18:17:16.723997 [NOTICE] switch_ivr.c:2231 Transfer sofia/external/Restricted@173.239.37.248 to XML[350@ippbx.bpsna.net]
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:559 action regex [350] [/^(\d{2,11})$/] [2]
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'set ${cond(${user_exists id 350 ippbx.bpsna.net} == true ? user_exists=true : user_exists=false)}'
2020-09-24 18:17:16.723997 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [user_exists]=[false]
2020-09-24 18:17:16.723997 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'set ${cond(${user_exists} == true ? user_exists=true : ivr_max_failures=${system(expr ${ivr_max_failures} + 1)})}'
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(ivr_max_failures=1)
2020-09-24 18:17:16.743980 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [ivr_max_failures]=[1]
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:559 action regex [350] [/^(\d{2,11})$/] [2]
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'playback ${cond(${user_exists} == true ? /usr/share/freeswitch/sounds/${default_language}/${default_dialect}/${default_voice}/ivr/ivr-call_being_transferred.wav : /usr/share/freeswitch/sounds/${default_language}/${default_dialect}/${default_voice}/ivr/ivr-that_was_an_invalid_entry.wav)}'
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:581 switch_ivr_menu_execute todo=[2]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 playback(/usr/share/freeswitch/sounds/en/us/callie/ivr/ivr-that_was_an_invalid_entry.wav)
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'transfer ${cond(${ivr_max_failures} == 3 ? )}'
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 transfer(-ERR)
2020-09-24 18:17:16.743980 [NOTICE] switch_ivr.c:2231 Transfer sofia/external/Restricted@173.239.37.248 to XML[-ERR@ippbx.bpsna.net]
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:577 IVR action on menu '534f42ce-cc21-4534-93d6-23db427e2277' matched '350' param 'transfer ${cond(${user_exists} == true ? 350 XML ippbx.bpsna.net)}'
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 transfer()
2020-09-24 18:17:16.743980 [DEBUG] switch_ivr_menu.c:673 exit-sound '(null)'
2020-09-24 18:17:16.743980 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE going to sleep
2020-09-24 18:17:16.743980 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_ROUTING (Cur 1 Tot 73)
2020-09-24 18:17:16.743980 [DEBUG] switch_channel.c:2293 (sofia/external/Restricted@173.239.37.248) Callstate Change ACTIVE -> RINGING
2020-09-24 18:17:16.743980 [DEBUG] switch_core_state_machine.c:643 (sofia/external/Restricted@173.239.37.248) State ROUTING
2020-09-24 18:17:16.743980 [DEBUG] mod_sofia.c:154 sofia/external/Restricted@173.239.37.248 SOFIA ROUTING
2020-09-24 18:17:16.743980 [DEBUG] switch_core_state_machine.c:236 sofia/external/Restricted@173.239.37.248 Standard ROUTING
2020-09-24 18:17:16.743980 [INFO] mod_dialplan_xml.c:637 Processing Anonymous <Restricted>->-ERR in context ippbx.bpsna.net
2020-09-24 18:17:16.763967 [ERR] mod_lua.cpp:202 ...hare/freeswitch/scripts/resources/functions/database.lua:194: attempt to concatenate a nil value
stack traceback:
...hare/freeswitch/scripts/resources/functions/database.lua:194: in function <...hare/freeswitch/scripts/resources/functions/database.lua:193>
(...tail calls...)
[C]: in function 'gsub'
...hare/freeswitch/scripts/resources/functions/database.lua:42: in function <...hare/freeswitch/scripts/resources/functions/database.lua:37>
(...tail calls...)
...hare/freeswitch/scripts/resources/functions/database.lua:131: in function 'query'
...pp/xml_handler/resources/scripts/directory/directory.lua:284: in main chunk
[C]: in function 'dofile'
/usr/share/freeswitch/scripts/app/xml_handler/index.lua:99: in main chunk
/usr/share/freeswitch/scripts/app.lua:48: in main chunk
2020-09-24 18:17:16.763967 [ERR] mod_lua.cpp:270 LUA script parse/execute error!
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [user_exists]=[false]
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [redial] destination_number(-ERR) =~ /^(redial|\*870)$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [speed_dial] destination_number(-ERR) =~ /^\*0(.*)$/ break=on-false
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [emergency_caller_id_name]=[UNDEF]
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [emergency_caller_id_number]=[UNDEF]
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [outbound_caller_id_name]=[UNDEF]
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [outbound_caller_id_number]=[UNDEF]
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Asus.1d10] destination_number(-ERR) =~ /^\+?1?(\d{10})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Test] destination_number(-ERR) =~ /^350$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [IVR] destination_number(-ERR) =~ /^360$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->agent_status] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [agent_status] destination_number(-ERR) =~ /^\*22$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [agent_status] destination_number(-ERR) =~ /^(agent\+)(.*)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->agent_status_id] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [agent_status_id] destination_number(-ERR) =~ /^\*23$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->group-intercept] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [group-intercept] destination_number(-ERR) =~ /^\*8$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->ACD] continue=
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [ACD] destination_number(-ERR) =~ /^([^#]+#)(.*)$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [ACD] destination_number(-ERR) =~ /^320$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->page] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [page] destination_number(-ERR) =~ /^\*724$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->page-extension] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [page-extension] destination_number(-ERR) =~ /^\*8(\d{2,7})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->eavesdrop] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [eavesdrop] destination_number(-ERR) =~ /^\*33(\d{2,7})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call_privacy] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call_privacy] destination_number(-ERR) =~ /^\*67(\d+)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call_return] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call_return] destination_number(-ERR) =~ /^\*69$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->intercept-ext] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [intercept-ext] destination_number(-ERR) =~ /^\*\*(\d+)$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [intercept-ext] destination_number(-ERR) =~ /^\*\*$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->extension_queue] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [extension_queue] destination_number(-ERR) =~ /^\*800(.*)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->intercept-ext-polycom] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [intercept-ext-polycom] destination_number(-ERR) =~ /^\*97(\d+)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->Regular] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Regular] destination_number(-ERR) =~ /^180$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->dx] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [dx] destination_number(-ERR) =~ /^dx$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [ACD] destination_number(-ERR) =~ /^315$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [ACD] destination_number(-ERR) =~ /^214 216$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [ACD] destination_number(-ERR) =~ /^214 216$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->send_to_voicemail] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [send_to_voicemail] destination_number(-ERR) =~ /^\*99(\d{2,10})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->att_xfer] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [att_xfer] destination_number(-ERR) =~ /^att_xfer$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->extension-to-voicemail] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [extension-to-voicemail] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->Fax] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Fax] destination_number(-ERR) =~ /^5162268256$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->vmain] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [vmain] destination_number(-ERR) =~ /^vmain$|^\*4000$|^\*98$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [vmain] destination_number(-ERR) =~ /^(vmain$|^\*4000$|^\*98)(\d{2,12})$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->xfer_vm] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [xfer_vm] destination_number(-ERR) =~ /^xfer_vm$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->vmain_user] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [vmain_user] destination_number(-ERR) =~ /^\*97$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->is_transfer] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [is_transfer] destination_number(-ERR) =~ /^is_transfer$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Test] destination_number(-ERR) =~ /^888$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->Day/Night Mode] continue=
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Day/Night Mode] destination_number(-ERR) =~ /^(?:flow\+)?\*66$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [Day/Night Mode] destination_number(-ERR) =~ /^199$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->cf] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [cf] destination_number(-ERR) =~ /^cf$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->delay_echo] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [delay_echo] destination_number(-ERR) =~ /^\*9195$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->echo] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [echo] destination_number(-ERR) =~ /^\*9196$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->milliwatt] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [milliwatt] destination_number(-ERR) =~ /^\*9197$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->is_zrtp_secure] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [is_zrtp_secure] ${zrtp_secure_media_confirmed}() =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 ANTI-Action eval(not_secure)
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->tone_stream] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [tone_stream] destination_number(-ERR) =~ /^\*9198$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->is_secure] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [is_secure] ${sip_via_protocol}(udp) =~ /tls/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->hold_music] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [hold_music] destination_number(-ERR) =~ /^\*9664$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->recordings] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [recordings] destination_number(-ERR) =~ /^\*(732)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->disa] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [disa] destination_number(-ERR) =~ /^\*(3472)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->directory] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [directory] destination_number(-ERR) =~ /^\*411$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->wake-up] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [wake-up] destination_number(-ERR) =~ /^\*(925)$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->valet_park] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [valet_park] destination_number(-ERR) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [valet_park] ${sip_h_Referred-By}() =~ /sip:(.*)@.*/ break=never
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [valet_park] destination_number(-ERR) =~ /^(park\+)?\*(59[0-9][0-9])$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->operator] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [operator] destination_number(-ERR) =~ /^0$|^operator$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->operator-forward] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [operator-forward] destination_number(-ERR) =~ /^\*000$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->do-not-disturb] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [do-not-disturb] destination_number(-ERR) =~ /^\*77$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [do-not-disturb] destination_number(-ERR) =~ /^\*78$|\*363$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [do-not-disturb] destination_number(-ERR) =~ /^\*79$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [do-not-disturb] destination_number(-ERR) =~ /^dnd\+Restricted$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call_screen] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call_screen] ${call_screen_enabled}() =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->follow-me-destinations] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [follow-me-destinations] ${user_exists}(false) =~ /^true$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call-forward] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call-forward] destination_number(-ERR) =~ /^\*72(\d*)$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call-forward] destination_number(-ERR) =~ /^\*73$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call-forward] destination_number(-ERR) =~ /^\*74$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call-forward] destination_number(-ERR) =~ /^forward\+(\QRestricted\E)(?:\/(\d+))?$/ break=on-true
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call forward all] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call forward all] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->call forward not registered] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [call forward not registered] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->follow-me] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [follow-me] destination_number(-ERR) =~ /^\*21$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->clear_sip_auto_answer] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [clear_sip_auto_answer] ${click_to_call}() =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->talking clock date and time] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [talking clock date and time] destination_number(-ERR) =~ /^\*9172$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->talking clock time] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [talking clock time] destination_number(-ERR) =~ /^\*9170$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->talking clock date] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [talking clock date] destination_number(-ERR) =~ /^\*9171$/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->local_extension] continue=true
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [local_extension] ${user_exists}(false) =~ /true/ break=on-false
Dialplan: sofia/external/Restricted@173.239.37.248 parsing [ippbx.bpsna.net->voicemail] continue=false
Dialplan: sofia/external/Restricted@173.239.37.248 Regex (FAIL) [voicemail] ${user_exists}(false) =~ /true/ break=on-false
2020-09-24 18:17:16.763967 [DEBUG] switch_core_state_machine.c:286 (sofia/external/Restricted@173.239.37.248) State Change CS_ROUTING -> CS_EXECUTE
2020-09-24 18:17:16.763967 [DEBUG] switch_core_state_machine.c:643 (sofia/external/Restricted@173.239.37.248) State ROUTING going to sleep
2020-09-24 18:17:16.763967 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_EXECUTE (Cur 1 Tot 73)
2020-09-24 18:17:16.763967 [DEBUG] switch_channel.c:2295 (sofia/external/Restricted@173.239.37.248) Callstate Change RINGING -> ACTIVE
2020-09-24 18:17:16.763967 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE
2020-09-24 18:17:16.763967 [DEBUG] mod_sofia.c:209 sofia/external/Restricted@173.239.37.248 SOFIA EXECUTE
2020-09-24 18:17:16.763967 [DEBUG] switch_core_state_machine.c:328 sofia/external/Restricted@173.239.37.248 Standard EXECUTE
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 set(RFC2822_DATE=Thu, 24 Sep 2020 18:17:16 -0400)
2020-09-24 18:17:16.763967 [DEBUG] mod_dptools.c:1615 SET sofia/external/Restricted@173.239.37.248 [RFC2822_DATE]=[Thu, 24 Sep 2020 18:17:16 -0400]
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 export(origination_callee_id_name=-ERR)
2020-09-24 18:17:16.763967 [DEBUG] switch_channel.c:1306 EXPORT (export_vars) [origination_callee_id_name]=[-ERR]
2020-09-24 18:17:16.783989 [DEBUG] switch_cpp.cpp:1187 sofia/external/Restricted@173.239.37.248 destroy/unlink session from object
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 hash(insert/ippbx.bpsna.net-last_dial/Restricted/-ERR)
EXECUTE [depth=0] sofia/external/Restricted@173.239.37.248 eval(not_secure)
2020-09-24 18:17:16.783989 [NOTICE] switch_core_state_machine.c:385 sofia/external/Restricted@173.239.37.248 has executed the last dialplan instruction, hanging up.
2020-09-24 18:17:16.783989 [NOTICE] switch_core_state_machine.c:387 Hangup sofia/external/Restricted@173.239.37.248 [CS_EXECUTE] [NORMAL_CLEARING]
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:650 (sofia/external/Restricted@173.239.37.248) State EXECUTE going to sleep
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_HANGUP (Cur 1 Tot 73)
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:847 (sofia/external/Restricted@173.239.37.248) Callstate Change ACTIVE -> HANGUP
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:849 (sofia/external/Restricted@173.239.37.248) State HANGUP
2020-09-24 18:17:16.783989 [DEBUG] mod_sofia.c:460 Channel sofia/external/Restricted@173.239.37.248 hanging up, cause: NORMAL_CLEARING
2020-09-24 18:17:16.783989 [DEBUG] mod_sofia.c:513 Sending BYE to sofia/external/Restricted@173.239.37.248
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:60 sofia/external/Restricted@173.239.37.248 Standard HANGUP, cause: NORMAL_CLEARING
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:849 (sofia/external/Restricted@173.239.37.248) State HANGUP going to sleep
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:619 (sofia/external/Restricted@173.239.37.248) State Change CS_HANGUP -> CS_REPORTING
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:584 (sofia/external/Restricted@173.239.37.248) Running State Change CS_REPORTING (Cur 1 Tot 73)
2020-09-24 18:17:16.783989 [DEBUG] switch_core_state_machine.c:935 (sofia/external/Restricted@173.239.37.248) State REPORTING
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:174 sofia/external/Restricted@173.239.37.248 Standard REPORTING, cause: NORMAL_CLEARING
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:935 (sofia/external/Restricted@173.239.37.248) State REPORTING going to sleep
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:610 (sofia/external/Restricted@173.239.37.248) State Change CS_REPORTING -> CS_DESTROY
2020-09-24 18:17:16.883980 [DEBUG] switch_core_session.c:1726 Session 73 (sofia/external/Restricted@173.239.37.248) Locked, Waiting on external entities
2020-09-24 18:17:16.883980 [NOTICE] switch_core_session.c:1744 Session 73 (sofia/external/Restricted@173.239.37.248) Ended
2020-09-24 18:17:16.883980 [NOTICE] switch_core_session.c:1748 Close Channel sofia/external/Restricted@173.239.37.248 [CS_DESTROY]
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:738 (sofia/external/Restricted@173.239.37.248) Running State Change CS_DESTROY (Cur 0 Tot 73)
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:748 (sofia/external/Restricted@173.239.37.248) State DESTROY
2020-09-24 18:17:16.883980 [DEBUG] mod_sofia.c:365 sofia/external/Restricted@173.239.37.248 SOFIA DESTROY
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:181 sofia/external/Restricted@173.239.37.248 Standard DESTROY
2020-09-24 18:17:16.883980 [DEBUG] switch_core_state_machine.c:748 (sofia/external/Restricted@173.239.37.248) State DESTROY going to sleep
mudasar321
81
Anyone get a chance to take a look? I'm getting below error.
2020-09-29 08:30:17.646551 [ERR] mod_lua.cpp:202 ...hare/freeswitch/scripts/resources/functions/database.lua:194: attempt to concatenate a nil value
stack traceback:
(...tail calls...)
(...tail calls...)
2020-09-29 08:30:17.646551 [ERR] mod_lua.cpp:270 LUA script parse/execute error!
agree
135
24
I know from this bug since it was committed just comment out lines number 282 and 284 of /usr/share/freeswitch/scripts/app/xml_handler/resources/scripts/configuration/ivr.conf.lua that should solve it
markjcrane
450
162
I've been testing this for the last hour and have been unable to reproduce the problem with the code as is. Worked on FreeSWITCH 1.10.2 and 1.10.5 and reproduced the problem on 1.6.20.
