3 way calling
Vishal Pai
Hello Everyone
Is it possible to achieve following scenario in fusionpbx. Here what i am trying to achieve.
Call comes on DID (Say A) which is routed to Extension (Say B) once it's answered by Extension it keeps that call on hold and make new outbound call (Say C) after that all three are merged and Extension hangup so that A and C should connected while Extension should ready for next call pick up.
bryanredeagle
29
La Porte, IN
haway.io
I'm not sure that's a thing you can do because, from Freeswitch's view, both calls are bridged to your phone. When you hang up, you are destroying those bridges. It might be possible if you were to have a phone that could transfer the calls to each other, but I personally don't know of any phone that can do that.
You might just be better off using a conference bridge. You can certainly transfer calls to it, and I doubt the caller would be none the wiser since they'll hear hold music when you put them on hold to get the other caller.
