404 Not Found nginx/1.12.1
75
Hello, I hope you are well, I have the following problem for a week when entering or changing any parameter in devices or extensions, it gives an error in nginx and it does not make the changes in the tftp I will add a video so that the error can be seen, can you help me with this ?
Hello, I hope you are fine, the video never loaded and I deleted it from the phone, the problem I currently have is that in a client with Cisco 7900 series phones, after a while everything worked normally, when creating or modifying a extension or device and clicking save takes a while to refresh and ends up giving an nginx 404 error, additionally it does not create or modify the file in the tftp folder (/etc/tftp) I hope you can help me see where the problem is, attached the error image.
