SOLVED 5.0.10 to 5.3.6 auto provision
s2svoip
267
doing some upgrade tests before I try it on the live system, my process is to do a clean install then a DB backup from old server and restore followed by all upgrade steps - this has served me well in the past however in this testing auto provisioning seams to have stopped working. Specifically when I go into a device and try to download the mac.cfg file, I get 404 not found. I am watching the nginx access logs but dont even see in entry when I try and download the file.
all the settings are the same from the old server where its working fine... unless something new has been added, its quite the version jump.
anyone offer any pointers where I might be able to look to get some more info as to whats wrong, cant see anything in log viewer either
check nginx error log. Maybe you have something there. If neither of the log have any entries than requests don't make it to your webserver
solved, thanks for the pointer @pbxgeek - yeah kinda silly, when you click to download the file it redirects to the actual tennant URL, which is pointing to my live server not the test one, so yah.
cheers
