R rossbcan New Member Jun 29, 2020 3 0 1 72 Jun 29, 2020 #1 have a voicemail recording delay issue (miss first 7 seconds after beep). FS-1.10.3, FusionPbx trunk, OpenWrt OS. Suggestions how to debug this? Thanks... Same delay internal, external calls
A ad5ou Active Member Jun 12, 2018 893 205 43 Jun 29, 2020 #2 My first guess would be codec match issues. Have seen similar results with a few different video enabled phones. check your logs and use sngrep to watch test calls so see where the delay is happening.
cp6183 Member Oct 29, 2019 76 3 8 41 May 17, 2021 #3 @rossbcan - did you you ever resolve this issue?
cp6183 Member Oct 29, 2019 76 3 8 41 May 17, 2021 #4 @ad5ou - when you say codec mismatch can you explain? What if I am unable to reproduce the issue, however. The delay still happens with customers?
