In FusionPBX, I have created multiple outbound gateways (for example, 4 gateways). I also have multiple extensions, and I want each extension’s outbound calls to use a specific gateway.
However, right now all outbound calls are going through only one gateway, even though:
So my main issue is:
How can I configure FusionPBX so that each extension uses its own specific outbound gateway, instead of all calls going through the same one?
- I have created multiple gateways.
- I have set Caller ID / External ID on extensions.
- I expected calls to route out based on the extension or Caller ID.
