Anveo gateway
dcitelecom
153
Anyone know how to setup an Anveo Gateway? The host is sbc.anveo.com Do I have to allow additional signaling IPs in the ACL list? In FreePBX everything works great but same settings in Fusionpbx fail. I keep getting CS_CONSUME_MEDIA] [NORMAL_TEMPORARY_FAILURE]
You'll need to add all of their IP's to your ACL
From their FAQ
You need to allow the following IP addresses to reach your network:
67.212.84.21 - SIP Signaling
176.9.39.206 - SIP Signaling
169.48.232.158 - SIP Signaling
72.9.149.25 - SIP Signaling
Reactions: dcitelecom
I found the issue. Apparently Anveo has a really low monthly spending limit by default and I exceeded it. Thanks guys.
Ah yes. low spending limit by default an only 10 channels. A quick support ticket resolves problem.
