Asterisk CLI and FreeSwitch/Fusion PBX CLI
jeetz
87
I was searching for a way to achieve the equivalent of "sip show peers" in FusionPBX. In Asterisk, we use this command to identify peers with a delay exceeding 300 milliseconds, displaying them in purple on a wallboard, and less then that icon is green.
However, FusionPBX doesn't offer a direct counterpart to this functionality. Do you have any suggestions or solutions for achieving the same outcome in FusionPBX?
Anyscrip orany command that would be useful.
Thank you.
What is a peer?
If you mean extensions then: show registrations
I'm not sure you will get what you want from that though
Yes, the command "sip show peers" displays a list of all the extensions and trunks that are registered on the PBX, along with the time it takes in milliseconds to reach and check their status. Cant we have something to replicate it?
