BLF light for DND on Yealink phone turns off after enabled
Telradtech
British Columbia, Canada
Hey everyone, I have this new issue after completing my new FusionPBX install 4.2, when I put my Yealink 46G in DND (*78/*79) the feature works perfectly except the BLF light of my extension on all other extensions returns to green state. Goes red for seconds and then goes back green. My phone remains in DND until i disable it but other users don’t know I’m in DND and try to transfer me calls. Is there a dial plan or script I need to add in the system to have this BLF light to stay lit for the total duration of the call. This is the first instance running into this issue.
Telradtech
After a little more investigation, I found the system is updating presence for dnd+EXT#. When I register a BLF button for that on my yealink phones it works. Having 2 separate BLFs for everyone is not going to work so is there any way for the system to update the extension number only? I have tried editing the blf.lua file unsuccessfully.
