SOLVED Call can not connect
vuthy09
141
12
My calling among extensions can not connect because I got an error of 407 proxy authentication required? how to solve this problem?
You have auth-calls enabled on your profile, which is good but the phone doesn't authenticate the call so it fails i guess..
Reactions: vuthy09
Hmm, wierd, are you sure that there isn't another invite being sent with proxy authentication header? Like this:
Depends on which profile you're sending the call, it would be the one listening on 5060 port, i guess that should be the internal profile by default?
thanks for ur help, now I repair my internal profiles and some calls are ok and some calls are not ok, when call is ok but no sound? so what is the problem?
