Call Canter run lua
Vahram
38
Hi guys
I want run lua script after pressing key: 1 and exit from callcenter (queue waiting)
Please help
As far as I'm aware there isn't a way to do this. Callcenter is a Freeswitch module and once transferred to there you are in it. I think it would take modification of the Freeswitch C code itself to do this. I could be wrong though.
Hello
I found solution
I have added in Dial Plan Call center XML
<action application="set" data="cc_exit_keys=1"/>
<action application="bind_digit_action"data="myrealm,1,exec:Lua,lua_script.lua,1"/>
working properly
But after press save key in Call Center Queue on the web page that setting was gone from xml
How can i add row between Exit Key and Description on web page?
