Call Center Agents Displaying Incorrectly
ThriveLife
12
Brand new installation of FusionPBX/Freeswitch, and noticed that the Contacts section of Agents under Call Center is displaying unneeded information.
Is there any quick way to resolve this?
The call_timeout=15 sip_invite_domain etc part of Contact. It seems that shouldn't be there, perhaps a bug? My old PBX installation simply shows user/ext/@domain. Not a big deal, just doesn't seem right.
@ThruveLife, This is not a bug as the code does what it is intended to do. The PHP script pulls the agent contact field information from the v_call_center_agents table in the db via a SQL query and displays it accordingly.
You could modify the script to use a regex expression to get rid of the {xxxxxx} part if it really is that bothersome. Of course the change may not persist if/when you upgrade.
